Evo X turbo swap (base map discussion)
I've started this thread to get input from all of you looking at (or have already done) an Evo X turbo swap in your Ralliart. I've been seeing the results and to say they are impressive would be an understatement.
It's something that I know a lot of us have considered at some point, I want this thread to summarise a some what baseline list of mods (aside from the obvious) that are required and potentially get a base map created for it.
I for one, live in an area where this kind of modification is still very immature and to have an OpenECU basemap would offer a tremendous leap of confidence in going ahead with such a change in my car.
So apart from what is listed in this thread, can we come to some kind of common ground that can get us off to a really good start for a base map? If we can stick to this rough format, it should make things easier.
Turbo: (New Evo X, Used Evo X, BBX Lite etc)
Wastegate Actuator: (Evo X stock, etc)
Boost pill: Yes or No
Downpipe: (Evo X O2 housing + 3" downpipe, O2/Downpipe combo etc)
Exhaust: (3", stock etc)
Intake:
FMIC:
IC Piping:
Battery adjustment: (Stock, Mini battery, Boot etc)
Installed already: Yes or No
AWHP:
AWTQ:
I'm sure there are other usuful elements that I've left behind so lets here them.
Intake:
FMIC:
IC Piping:
AWHP:
AWTQ:
What are you suggesting here?
If you have no tuner near you, and you want to mod your car, the obvious solution is that you need to start tinkering with your own tune. I am somewhat surprised that I have seen virtually no interest in the RA community exploring this area.
I do agree though. It would be great to have a thread that would discuss various tuning aspects related to the turbo swap. I hope this turns into something useful
Sorry to go off topic. Just wanted to add my 2 cents!
My intent for the thread was no so much to talk about the ins and outs of tuning (although I think it would be very useful to have one more specifically for the RA), but to summarize what combination of supporting mods people had, or were intending to add to their RA alongside the Evo X turbo.
I agree that we won't get the volume of people in the RA community tuning their own cars, but if a happy medium of mods could be established I thought a base map could be a good place for people to start.
i'd probably get the BBX Lite, 1000cc injectors, AMS fuel rail, ETS bottom mount manifold, ETS 3.5" FMIC, ETS LICP, 255LPH fuel pump, AMS transmission cooler, upgraded oil cooler, and Mishimoto evo x full aluminum rad.
i haven't researched where people start to experience valve float in these vehicles, but it's probably a good idea to get upgraded valves prings anyway. anyone who likes to rev these little engines to 7K would be better off getting them. while you're in there, might as well spring for the AMS cam cap and some upgraded cams like the GSC S1's.
That's quite a hardcore list of mods wouldn't you say. Only necessary if you were planning on pushing the car hard on a regular basis. My list would look something like:
Turbo: BBX Lite
Wastegate Actuator: Included in BBX Lite
Boost pill: GST Motorsports
Downpipe: UR O2/Downpipe
Exhaust: UR high flow cat (metal) and cat back
Intake: Still looking into this one
FMIC: ETS 3" Evo X
IC Piping: T1R upper and lower
Battery adjustment: Prefer to keep it stock (depends on intake choice)
Installed already: No
AWHP: 315 goal
AWTQ: 295 goal
Turbo: BBX Lite
FMIC: ETS 3" Evo X
AWHP: 315 goal
AWTQ: 295 goal
Turbo: BBX Lite
FMIC: ETS 3" Evo X
AWHP: 315 goal
AWTQ: 295 goal
Turbo: BBX Lite
FMIC: ETS 3" Evo X
AWHP: 315 goal
AWTQ: 295 goal
I would go for the bbx lite as well. Byan is gaining some excellent results. Can't wait to see his E 85 numbers.
I think if you go ETS for a fmic, you should also get there piping. They can work out some good package deals.
My mods are pretty basic:
Ams Intake
Ams single catback
Ams testpipe
Ams boost pill
UR uipc and licp
EvoX stock fmic and metal bpv.
I plan to upgrade to a X swap or throw in a bbx lite next year along with bigger injectors and a pump running E 85.
What about handling mods? Lowering springs, coilovers, sway bars, h brace....
ah.
I think 6800 I stock, 7100 with Bryan's base map. My ETS FMIC and T1R pipes are just waiting to be installed. I'll look into the ETS intake, although was curious about the DIY option on another thread here (uses an EVO X pipe part with cone filter).
Any current turbo swapped guys care to chime in. What works, what doesn't?
Can I ask you: is your AEM intake an evo x model or a RA model that has been modified in some way to fit the BBX Lite turbo?
Evo Turbo swap help needed
I could use some help with my EVO X turbo swap. After swap the vehicle is making less power than the tuned Ralliart turbo with the mods below - 200 HP vs. the 252 with the Ralliart turbo.. Does anyone have the MIVEC map that works for the EVO turbo? Any one with experience with installing an intake on the Ralliart after turbo swap? Evo intake or Ralliart spec'd intake?
