Need some help with 3xMAP tables.
I need the xml for a 5360010/09
heres what i have in the evo10base
<scaling name="Loadify" units="%" toexpr="(x*10/512)*10/32" frexpr="(x*32/10)*512/10" format="%.1f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
<table name="MAP based Load Calc #1 - Hot/Interpolated" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
<table name="MAP" type="X Axis" elements="19" scaling="JDMMAPpsi"/>
<table name="RPM" type="Y Axis" elements="19" scaling="RPM"/>
</table>
<table name="MAP based Load Calc #2 - Cold/Interpolated" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify"> <table name="MAP" type="X Axis" elements="19" scaling="JDMMAPpsi"/>
</table>
<table name="MAP based Load Calc #3" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
</table>
Thanks for the help.
Also its apparent that i'm missing some fuel control. But i'm hoping that changing the scaling will allow for more control because load is all jacked on the X turbo.
</table>
</table>
</table>
Ah so you found out the problem as well when putting larger turbos on the RA.
Scaling is the same as the Evo 10 because they both use 3 bar map sensors.
You just need to copy paste the evo 10 data in the main table (s).
For 09 RA:
<table name="MAP based Load Calc #1 - Hot/Interpolated" address="604a0">
<table name="MAP" address="62a90"/>
<table name="RPM" address="62a64"/>
</table>
<table name="MAP based Load Calc #2 - Cold/Interpolated" address="601c4">
</table>
<table name="MAP based Load Calc #3" address="5fee8">
</table>
- Bryan
For 09 RA:
</table>
</table>
</table>
- Bryan
I've been trying to read and find out what exactly these tables do, and why they differ between the RA and Evo. I realize the turbo is different but not sure how this relates to these tables. I'm obviously missing some theory here. Can someone clear this up for me? Throw me a link or something?
Here is the difference between maps for anyone's curiosity. Evo on top.
I'm not a pro-tuner or anything but this is what i've found to hold true on my friends car.
They differ between the RA and the Evo because of airflow difference between the RA turbo and Evo. Basically the ECU uses this as a VE table and calculates load based on how much air it thinks it has per cylinder per stroke. When you upgrade turbos the new turbo actually outputs more air than the ECU thinks it has.
with upgraded turbos on RA's is the ECU thinks the turbo is beyond its range and not flowing adequately.
Basically your load will be going down when you know it should be increasing and you're sitting there like what the **** is going on with this thing if you don't edit these tables.
oh and the car went a best of 13.0 @ 107 he wouldn't launch it which i don't blame him..
Thanks to bryans help
Wouldn't the trap speed increase if launched/footbaked ?
Yeah, street tuned by myself.. 22psi
I feel like theres more power in it but i was having trouble with boost patterns because my load was all jacked and i didn't want to halfass it and disable error correction. So i left it at 22-19 and still very rich up top.
I wish i could've devoted more time to it lastnight but it was another friends birthday and hes had a evo 8 for 3 years now.. 3 built motors.. and hadn't ever made a pass in it so i was helping him. 12.1 @ 122 first night ever launching his car he loved it too.
I see, so the turbo is moving more air at the same pressure hence the increased load at the same MAP.
So I guess there would be no reason to adjust these if the turbo was left stock, and you weren't running cams or a ported head or something that increased flow?
What would the main calculations that would be thrown off if these maps were not adjusted?
What if you were spraying meth and condensing the air before it entered the intake manifold, could this potentially be a reason to tweak these maps?
What symptoms would there be if these tables were off for a particular setup?
Bryan, you mentioned initial issues with the BBX Lite that affected the SST. Could you elaborate a bit on the specifics?
Until you are having issues IE your load patterns are like something you've never seen before. You have no reason to modify these tables
However when you upgrade turbos this becomes a very big issue.
If your car does what it's suppose to. Don't worry about it.
Whats the point in meth on stock RA turbo anyway?
Not that much is seems....Just an experiment and prep for possible turbo swap, and a bump for the 91 octane. I got some more timing out of it, that's about all.
The reason I ask, is because since the meth, my load graph looks like someone ripped the peak off. Between 3500 and 4500, the load curve is flat and jagged. Changes in the WGDC have no effect at all. The load flattens at about 228 load. This is not my target, so don't think its error correction.
Maybe I have a leaking BOV, although the boost plot doesn't seems to share this characteristic. I hope to put a evo BOV on this weekend and see if it solves this problem
