Error Code: P0420
Error Code: P0420
Last acouple months I have had CELs and cleared DTC's. Today ago another CEL and thru EVOscan I read the code.
P0420 - Catalyst system Efficiency below the Threshold (Bank 1)
What is my RA telling me? Bryan from GST?
I'm presently custom AMS Flash with boost pill, however switched up GST 91 V2 to see if I have any CEL with the cold weather coming.
Evil03, what do u mean "need to space out the rear o2 sensor"? The UR Cat has the same position for the O2 senor as factory Cat.
urmm if your tuned you shouldnt have this problem...
but any how
here is how to fix that problem i am stacked 3 deep (1) HELP! 42009 (2) HELP! 42002 HELP! last one is drilled out 1/2 to fit the o2 sensor.. 12k no problem
but any how
I've got the same code with the UR test pipe, even with their bung. I purchased a 90 degree bend O2 spacer that is popular with the VW guys. Hopefully I can get this installed soon and get rid of that pesky CEL.
You can disable the rear 02 by setting Options 2 bit 1 => "0".
You will probably get a p 139/140 after that.
I have the xml for that code posted in this thread for 53600010.
This has worked for my test pipe.
anyone with an aftermarket dp/test pipe will probably get the code.
Essentially its telling you the cat is not efficient and is allowing pollutants into the atmosphere.
Nothing to worry about. I got tired of clearing it months ago.
Haven't got another code, but I was away and cleared it. I re flashed my ECU with GST 91 V2 and all seems well. I been running UR HF Cat since June/July and only got the code acouple times. But I noticed the turbo cutting in and out under hard acceleration since the re-flashed.
evoyao
28
Dec 5, 2010 06:21 PM
antics22
Sep 15, 2008 07:30 AM
