CBRD RAD Turbo
Old Jun 7, 2011, 11:02 PM
ltn
ltn's Avatar
CBRD RAD Turbo
So I'm looking on getting some parts for the car and I know I'm going to be hitting Mike up from RRM for an exhaust but I'm also looking to upgrade my turbo. I don't think I'm interested in doing all the work and putting out all the money for a evo x swap. I'm leaning toward the CBRD RAD turbo but I really haven't seen anyone with one yet. My question to everyone is. Does anyone have one and what kind of gains can I expect to see? I have tried to contact CRBD directly but I thought I would come to the message boards for some customer feedback. Thanks.
Old Jun 8, 2011, 03:54 AM
Mad_SB's Avatar
the search function is your friend:
https://www.evolutionm.net/forums/09...alliart-2.html
Old Jun 8, 2011, 09:07 AM
ltn
ltn's Avatar
Thanks, I have actaully read his thread and i was looking for some other people's opinion plus it was weird how he said the turbo was larger than the stock evox one. I thought they were a direct replacement for the stock ralliart turbo.
NFSLancer do you know how it is larger than the stock evox turbo?
Old Jun 8, 2011, 11:49 AM
RideSober's Avatar
Assuming the gaskets get here tomorrow as expected, I am having my CBRD RAD turbo installed tomorrow, and then the car should be tuned on Friday.
I'm not bothering with having any baseline tests done, just a stable tune on a stingy mustang dyno. I'll be sure to share some feedback.
Old Jun 8, 2011, 12:45 PM
bronto11588's Avatar
i would assume internal is bored out to larger than evo x stock bore
Old Jun 8, 2011, 01:04 PM
jkennedy293's Avatar
The housing should be the same size since it uses an RA core. I believe NFS was referring to the interior measurements when he said it was larger than the evo x turbo.
Old Jun 8, 2011, 01:15 PM
ltn
ltn's Avatar
Thanks guys I was kind of assuming he was talking about the internals but I wanted to make sure. Ridesober please do update us as I'm pretty sure I'm not the only one interested in results.
Old Jun 8, 2011, 01:24 PM
Jay10Ralliart's Avatar
Yeah you arent the only one interested. Im looking to buy the RAD as well and would like to see the dyno numbers!
Old Jun 8, 2011, 03:46 PM
npham455's Avatar
Yup, add me to the list waiting to see more results before I jump. Sounds like a more cost effective way that going to a full Evo X turbo swap.
Old Jun 9, 2011, 08:18 AM
Mad_SB's Avatar
Flow rate man. It's a stock RA frame turbo with upgraded internals.
I just talked to Chad about it, The RAD is rated at 38 lb/min while the Stock X turbo is 36 - 37 lb/min. The RAD also includes a 20psi actuator.....
Old Jun 9, 2011, 04:47 PM
nunyas's Avatar
that's still pretty damn good, IMO..
that 38lb/min figure; is that RAD full or RAD Lite?
Old Jun 9, 2011, 07:04 PM
03chi-town0Z's Avatar
I believe the main difference between "full" and "lite" was only the turbine material, iirc. This meant more in terms of quicker spool than much else, from what it sounded like anyway.
Chad would be the one to ask, but I believe he even said that it really wouldn't even be worth producing since even the stock turbo can push peak torque early enough that the RAD "full" wouldn't be worth the extra cost over the standard RAD, not to mention the headaches it would cause with the SS-T.
This is all from a fading memory, so correct me if I'm wrong.
Old Jun 9, 2011, 07:30 PM
Slee256's Avatar
Has anybody found out for sure whether the stock injectors need to be upgraded when installing the CBRD RAD turbo? I've heard mixed opinions on this, and was hoping for a definitive answer.
Old Jun 10, 2011, 11:56 AM
RideSober's Avatar
Steve, I should be able to provide the answer to this question very soon.
My car is being tuned right now.
Old Jun 10, 2011, 12:41 PM
ltn
ltn's Avatar
please keep us updated I think we are all interested.
Quick Reply: CBRD RAD Turbo
