How are the clutches, I hear these things go well on a 1/4 mile and would be interested in your stats on it(if any).
Clutches are holding just fine. I have not went to the track yet on the new setup. Should be high 11s.
Originally Posted by glenn1234
nice gain!
Ive got 1000cc injectors as well and im running a walbro 255 on both 98ron and E70-85 flex fuel. Thats on a Ef2 so your bigger red might get by or maybe slightly bigger pump for some extra overhead.
Thanks! Ordering a bigger pump next week for that reason lol.
Final numbers 391/333 @26psi on a dyno dynamics. Still on pump gas (93 oct). +47hp/ +11tq over previous tune.
That's on the same DD?!? Wow that is awesome!
My Red is on hold for the moment, I almost positive my seals in the SST are leaking (it won't hold above 60% TPS )
Yep same DD. A little bit colder this time around. I will post the sheet as soon as I get home from work. That sucks man. I hope you get everything squared away so you can put that red to use.
