COBB v300 USDM 2009-2014 Ralliart Beta OTS Maps
Hey guys!
We've recently spent quite a bit of time refining our Ralliart OTS maps as well as completing OTS map support for all 2009+ USDM Ralliart vehicles.
Make sure your Accessport firmware is up to date using Accessport Manager, you can then download the OTS maps at the link below.
V300 maps have been moved to full release. You can download the maps on the COBB Tuning website or you can get them via a firmware update.
Stage 1 Maps are for cars that are completely stock, aftermarket catback exhausts should be compatible. Target boost is 18.5psi tapering to 13.5psi at redline. (+/- 1.5psi)
Stage 2 Maps are for cars using a COBB 3-port EBCS and are otherwise stock. Target boost is 21 psi tapering to 16psi at redline (+/- 1.5psi)
Stage 3 Maps are for cars using a COBB 3-port EBCS as well as a COBB Downpipe, Testpipe, and an aftermarket catback exhaust system. Target boost is 21psi tapering to 16psi at redline (+/- 1.5psi)
Please note, ALL OTS maps are calibrated using the factory airbox. Aftermarket intake support is not available at this time.
Please note that these are still considered Beta maps. Once we (and you, the customers) are completely comfortable with these calibrations we will push them to a full release status on our website. Feel free to send us your datalogs here or at mitsubishi.experts@cobbtuning.com and we'll be glad to take a look at them for you!
As always, thank you for your continued support!
COBB Mitsubishi Team
yaay progress is being made,
also, what exactly are you looking to see in the datalogs, just so everyone knows and doesn't send you a million emails asking?
also i probably already know the answer to this but i don't suppose a Pierburg 3 port is at all safe to run with these?
or are all 3 ports not created equal?
Does the Stage 3 map require the Cobb components or would it work with any similar 3" downpipe/high flow cat? I have a CP-E downpipe and Turbo XS high flow cat...
Also the v200 maps didn't require the EBCS at all, are you planning a turbo back exhaust map that won't need that? I kind of liked the option to go back to a fully stock tune when bringing the car to the dealership for service, so it'd be a pain to have to install and uninstall the EBCS...
I have turboxs down pipe and high flow cat with custom exhaust. I also have a Cobb 3 port sitting in my room. Cobb please let us know if this beta map will work for us!
You should be good to go! Enjoy the new found power.
I looked at the logs that I made with the v300 map yesterday and they are puzzling to say the least. The car barely had any boost AT ALL, so the new version of this tune really isn't working properly for me (in fact it is worse than the stock tune). I didn't really expect much from just another Stage 1 map, but this is pretty sad.
As soon as I reverted back to the v200, the car returned to its normal performance and easily hit boost. I'm not planning to touch these v300 maps again until they are fixed.
So a 3 port has to be custome tuned... but you need a 3 port to run stage 3? what if i have everything but the 3 port, do i just install the 3 port and then flash stage 3??? and that covers the custom tune i need?
anyone else tried these stage 3 yet?
I have an 09 ralliart mods:
Ultimate racing down pipe
Ultimate racing mini muffler test pipe
ultimate racing cat back... all 3"
Evo X intercooler
Evo X BOV
Ultimate racing UICP
Evo X LICP
SRI K&N (DIY)... works great.
GSTmotorsport V31.003 tune (TBE, Boostpill...93)
Ultimate racing boostpill.
I want to try out this stage 3 map. I know i have to take out the boostpill and place a 3-port instead(preferably COBB's) to be able to run this map. I was just wondering if i would be OK with the rest of the mods i got right now?
Any Changes/reccommendations anyone has? Would i be ok with changing only the boostpill for a 3-port?
Evo X intercooler
Evo X BOV
Evo X LICP
You should be OK with your setup if you switch back to the factory intake (aftermarket intakes have no performance benefit for our cars and require a custom tune to work properly). If you read the first post here, you'll notice that "ALL OTS maps are calibrated using the factory airbox. Aftermarket intake support is not available at this time."
In any case, I don't see a reason to change to Cobb if you already have the GST tune (hopefully one that supports your intake... otherwise you're doing it wrong). The two methods are very similar, you're just changing one for the other and wasting $100 in the process.
Not quite!..... GST and COBB stage 1 map yes very very close.
GST and COBB stage 2 map = Completely different sotry.
My Buddy has the same exact mods i have i mean down to the tee. I have GST he has COBB stage 2, Atleast a 2 cars ahead of me all the time. Regardles of if we do a roll or we dig. Stage 2 93 is the best bang for buck for this platform other than getting a custom tune. That is why i am so interested in this stage 3. But COBB don't seem to add too much support into the mix. Especially when it comes to intakes. We have been waiting 2+ years for some intake maps but have yet to see one. Subaru on the other hand has like 10000000000 different maps.
