SST transmission fluid overfill
I have a 2010 RA sportback and when I bought it the plastic cover was over the transmission was cracked so it was losing tranny fluid. I have no clue how much was lost so I replaced the cover and drained all that was remaining. After that I bought the correct Daquin sst fluid 4 liters each and poured two of those in. I Read I needed only like 7.5 but I wanted to make sure. I started the car and everything but the car won't move if it's put into drive or reverse. Anyone have any suggestions?? I already drained some out thinking I poured too much.
I am not really mechanically inclined but I also have a 2010 Ralliart Sportback with a leaky transmission.
It turned out to be a common manufacturing defect for early Ralliart. I end up having to get the whole thing replaced via warranty.
How does your trans shift? Hard and noisy even in normal/auto?
Good luck.
Good luck.
It said transmission service required, should loosen that hex bolt while it's running? When do I know it drained enough?
•P2733: Clutch/shift switching solenoid 1, spool stuck That's the code I just got
moody91180
Mitsubishi TC-SST Discussion
Oct 11, 2014 06:22 PM
ecl27
12
Mar 3, 2014 10:28 PM
SmurfZilla
13
Oct 6, 2012 01:29 PM
TKVK1
Dec 19, 2006 09:37 PM
