How to: Remove spoiler 08+ RA
Not for everyone but a quick how to on removing spoiler...
Only requires a 10mm socket screwdriver:
Step 1:
Pop your trunk.
Step 2:
The spoiler is bolted down with two nuts (on each side) that you can remove with a 10mm socket driver here:
(repeat to opposite side)
Step 3:
Gentley pull up on your spoiler (the spoiler is one threaded screw attached to it that can scratch your hood easily if not careful, I wasn't It should pop out fairly easily, there is slight adhesive on trunk (more to just protect rubbing on the paint than holding it down). ***edit: other evom member saying his was hard to remove b/c of adhesive*** There is also plastic clip that is also permanently attached to under spoiler that comes out from the trunk hole not is in the rain drain.
First circle on left is the plastic clip on bottom of spoiler that comes out with ease. Circle on right is the screw attached to the spoiler *be cautious of when lifting up so it doesn't scratch against trunk.
Step: Wingless
***WTB a Do-Luck style duckbill trunk / Quality replica for 09 RA if anyone knows please PM me thanks***
Step 1:
Pop your trunk.
Step 2:
Step 3:
Step: Wingless
hrm thanks will make note, mine was like barely even adhesive, only one of side it seemed like it with just foam on the other, came up really easy
RRM has a carbon fiber lip kit for the trunk: http://www.roadracemotorsports.com/s...roducts_id=408
Would probably look best on a black car.
Rain and water will get in, yes. But I think the holes are right above the "gutter" in the trunk, where the water can drain out.
A cheap fix I've seen, is a vinyl strip - color matched as close as possible to the car.
If you really want it done right...take it to a body shop and have them fill it. OR, just buy an OEM trunk sans holes for the days you want to go wingless.
hey sorry guys for late response, when i took the pics i didn't have any plugs... you can get them at the dealership for like 5$ and its ok if you just want it off for the day without plugs because detroit RA is right-- the holes are right above the drainage for water
Nice how-to higgs.
I was considering removing the wing but am concerned about the holes, as my local dealer was not aware of the "plugs" you had mentioned. I saw another DIY for removing a wing on a Mustang in which the guy got some plastic plugs from Home Depot or something, painted them with touchup paint, and added a small bead of silicone to weather protect.
Question: Do you remember if all four holes were equal in size/diameter? Also, do you remember what size the holes were?
I'd like to do this project but want to make sure I can finish off the aftermath nicely like yours turned out. Thanks!
