HOW TO: Remove Stock BOV for EVO X BOV
Old May 5, 2013, 01:26 PM
  #31
Tobiatsu's Avatar
thread bookmarked, now to get my hands on an evoX bov...
Old Jul 18, 2013, 12:34 PM
  #32
Maj3st1k's Avatar
Just did this myself, hella easy but I had already swapped my OEM RA for a VTA
Old Jul 20, 2013, 05:40 PM
  #33
xDarKnighTx's Avatar
VTA is not recommended for our car. Might want to look into a recirc instead.
Old Jul 27, 2013, 06:54 PM
  #34
AlDim's Avatar
Just installed an Evo X BOV. It was very easy, but the little clamp from the vacuum hose jumped into the engine bay, never to be found again... >_< Everything works fine, but I still need to find a replacement. Unfortunately so far I've had no luck finding one online. Any ideas?
Old Jul 29, 2013, 03:18 PM
  #35
brains613's Avatar
So I just bought a BOV. The person who removed it had cut the hose, so the clamp was still on it. I still have it sitting on my TV stand. Shoot me a PM.
Old Dec 10, 2013, 05:46 AM
  #36
dangina's Avatar
Sorry for the noob question, but how do you tell the physical difference between the oem and the EVO? are part #'s different? size? I'm probably buying mine used online (nothing around where I live), and would like to know the difference between the two...
Old Dec 10, 2013, 10:00 PM
  #37
AlDim's Avatar
They look almost identical, but the Ralliart BPV is black and made of plastic and the Evo X one is a metal piece.
Evo X BPV:
Old Dec 11, 2013, 03:20 AM
  #38
dangina's Avatar
Evo X BPV:
Thanks for this!!!!!!
Old Dec 12, 2013, 11:58 AM
  #39
Veronica's Avatar
(and remember - you can use an EVO IX one as well - which are usually found cheaper...)
Old Mar 10, 2014, 05:25 PM
  #40
LightSkinBro's Avatar
Just got mine off of eBay a week ago. Planning on installing it this spring. Will post pics, seeing the original post isn't available any more.
Old Mar 26, 2014, 07:44 PM
  #41
Murdered Out's Avatar
Did mine today too! took 5min then 15min to get the screwdriver i dropped into the bumper out...
Old Apr 8, 2014, 10:52 AM
  #42
mattnshell's Avatar
Should only take bout 1 mins to swap them out long as u don't mess the tubes up. Super easy install.
Old Apr 18, 2014, 06:05 PM
  #43
hamy2308's Avatar
I got mine last Monday, had it on it a minute. my little hose points into the motor? works good and sounds nice. also noticed I can hear spool more and hear the actual blow, better than the stock plastic pos
Old Apr 20, 2014, 10:06 AM
  #44
hav0k's Avatar
looking to get one of these as well for my '09 RA can someone confirm if this is the correct one: Part # 1545A001?
https://www.lancershop.com/customer/...cat=172&page=1
thanks in advance!
Old May 16, 2014, 03:34 PM
  #45
BlackMamba88's Avatar
This will work but the vacuum hose that goes to the intake manifold will need to be extended.
Quick Reply: HOW TO: Remove Stock BOV for EVO X BOV
