HOW TO: Remove Stock BOV for EVO X BOV
#46
did you ever move it from pointing into the motor? mine does too but seems to work fine?
#47
I just did mine with the Evo X BOV. Literally takes 4 minutes. Mine points directly at the UICP and is slightly rested on it but not kinked at all. Hopefully the rubber piece doesn't melt lol
#48
Swapped mine over tonight, had to change over the vacuum hose to something longer:
What do you think, is there enough heat coming off the IC piping to cause any problems? Should I be looking for a more permanent solution?
Thanks in advance.
Thanks in advance.
#50
^which BOV did you get? EVO IX or X?
Either way - general guidelines:
Buy it too long - it is easy to cut!
Use standard vacuum line. Nothing special. Use clamps.
'Shorter is better' but kinked is very bad! No too-tight radius for bends & and ensure the hood doesn't pinch it down when closed.
#51
#53
I just installed my oem X BOV. only took 5-10 mins to do. I did struggle a lol getting the hose off of the nipple of the RA bov. I can feel my car pull better.definitely a sound difference. A good one in my opinion.
I painted mine a glossy purple. 2nd best affordable mod you can do.
#56
Ordered mine on Wed. It should be here later next week. $222.00 from my local Mitsubishi dealer. Next is an EVO X intercooler and upper and lower pipes from somewhere.
#57
Picked mine up from the dealership parts department yesterday and installed it today. What a big difference. The car seems to pull harder and hold boost throughout the entire rpm range. It did make a difference for sure. I could not push the diaphragm in on the EVO X one with my thumb but could easily on the plastic stock one. Definitely worth doing to a Ralliart.
#58
#60
I'm looking into this myself, and here's the info I've compiled so far if anyone is looking to order parts new by part number:
1507A009 is the stock RA by-pass valve (AKA valve, air by-pass according to some parts catalogs) and it's made out of plastic.
1545A001 is the JDM Evo VIII-IX BPV, made out of metal, with a less convenient location for the vacuum line.
1545A007 is the Evo X BPV, made out of metal, with a more convenient location for the vacuum line.
Anth (Mar 29, 2018)
