Ralliart driveline fluid change summary with part numbers and torques
Old Sep 8, 2012, 09:56 AM
hccyong's Avatar
Post Ralliart driveline fluid change summary with part numbers and torques
Hi, I recently did my transfer, TC-SST and rear differential oil changes on my 2010 Ralliart Sportback. There are detailed procedures and photos all over the forums, but many of them were Evo specific so I thought I'd summarize the Ralliart details here after having found some differences. Also, many threads I stumbled upon didn't provide the tool sizes or washer part numbers. If you notice any discrepancies, let me know, and I'll update this message so it stays accurate and useful.
Transfer (front/center differential):
  • Drain plug: 15/16" socket (24 mm would also work but a bit loose). 32 Nm / 24 ft-lb. Washer part number is 3200A102.
  • Fill plug: 17mm socket. 32 Nm / 24 ft-lb. Washer part number is MF660036.
  • Mitsubishi fluid is Diaqueen LSD SAE-90 (1 gallon container which will more than suffice). Part number is 3775610 (not confirmed).
  • Over 1 liter came out for me.
Rear differential:
  • Drain plug: 10 mm allen (3/8" might work but would be quite loose). 32 Nm / 24 ft-lb. Washer part number is MB001294.
  • Fill plug: 15/16" wrench of crow's foot (no room for socket). 32 Nm / 24 ft-lb. Washer part number is MF660036.
  • Only about 500 mL came out for me. Lots of iron filing the first time, barely any the next times.
TC-SST:
  • Drain plugs: 8 mm allen. 25 Nm / 18 ft-lb. No washer. Most documentation shows 3 drain plugs. However, on my car, my transmission only had 2. (One of the rear drain plugs' bosses was present but not drilled or tapped for a plug.)
  • Fill plug: 8 mm allen. 25 Nm / 18 ft-lb. No washer.
    Note this is under the battery for the Ralliart, so the air duct and battery need to be removed. The air filter and box do not have to be moved (unlike the Evo). This plug is also partially hidden by a wire harness support so that would need to be removed too for easy filling.
  • Filter: 32 mm allen. Unknown torque. Part number is 2513A040. No washer.
  • Mitsubishi fluid is Diaqueen SSTF-1 (1 gallon container so you'll need more than one container). Part number is C0002610 (not confirmed).
  • About 5.8 liters came out for me (including the fluid in the filter housing and the transmission cooler.
Old Sep 8, 2012, 03:17 PM
robertg's Avatar
Thanks for sharing.
Old Sep 14, 2012, 09:50 AM
CFMP RAblue's Avatar
Great info but I thought the SST held like 1.5 - 2 gallons?
Old Sep 14, 2012, 10:35 AM
hccyong's Avatar
Yes, I meant that the fluid container is about 1 gallon, so you'll need more than one container.
Old Oct 15, 2012, 03:06 PM
JayK's Avatar
I just did my transfer case and rear diff this past weekend following one of the EvoX's how to's. I wish i saw this thread, because I was very confused when looking for the torque transfer part of the rear differential.
I guess all we have is the differential mechanism part to change out. Purchased the DIAMOND ATF SP III for nothing, good thing it wasn't that expensive.
Old Nov 4, 2012, 10:04 AM
GetFoxed's Avatar
Doing this on your own, How long per Job?
SST - (x) Hours
Transfer - (x) Hours
Rear Diff - (x) Hours
Did you also price it out at your dealer?
I am at the 30K mark, so I will be doing this any day now...
Old Nov 4, 2012, 07:45 PM
gaabbee's Avatar
SST - (x) Hours
rear diff 10 mins
transfer case 15 mins..weird angle for fill
SST 30-35mins, like 2 gallons of fluid to fill plus removing air filter box, plus the filter is kind of a weird location but you can get to it by pulling the fender liner back, on the driver side.
I did this all on a lift so add maybe 5-10 mins for jacking the car up?
Its not hard at all trust me.
Old Nov 12, 2012, 07:57 AM
Fuego's Avatar
When I did the SST drain it was about 7.5 Qts, don't forget to drain the transmission cooler as well. I had 3 plugs on the bottom.
This is what I used when I did my services. It's also all in my build thread also :-)
How to change oil
https://www.evolutionm.net/forums/09...b-edition.html
How to Remove Bumper
https://www.evolutionm.net/forums/09...nt-bumper.html
https://www.evolutionm.net/forums/ev...lustrated.html
SST Oil and Filter change! Now I need to pick up two gallons of mineral oil.
https://www.evolutionm.net/forums/09...er-change.html
https://www.evolutionm.net/forums/09...sst-trans.html
Rear Diffs
https://www.evolutionm.net/forums/ev...t=LSD+changing
https://www.evolutionm.net/forums/ev...il-change.html
Pics of where the bolts are
https://www.evolutionm.net/forums/ev...ld-change.html
Bleed Brakes
http://www.joe250.com/cars/evo8/brak...ebleeding.html
Power Steering
https://www.evolutionm.net/forums/la...sh-change.html
http://www.dvatp.com/bmw/diy/power_steering_flush/
Radiator
https://www.evolutionm.net/forums/ev...ns-needed.html
For the STT fluid I used this link
https://www.evolutionm.net/forums/mi...sst-fluid.html
I used pentosin FFL-2 which Mitsu just tested in my car and it passed the test. Just wanted to inform all :-)
Old Nov 12, 2012, 08:45 AM
Dbzguy's Avatar
Good info. So whats the cost difference of doing this yourself vs Dealer?
Thanks!
Old Nov 12, 2012, 09:27 AM
Fuego's Avatar
I believe with the SSP OEM filter and 8 qts of oil ffl-2 for under $250, if u go with the dealership it's going to be above or close to $500. If u get the SSP reusable filter the. It will cost u under $200 per oil change.
My recommendation is to change ur oil every 15k miles. again just my recommendation! Cheers!
Old Jul 13, 2019, 04:47 AM
Heliart's Avatar
I just did my rear diff fluid change, I had a can of LSD fluid that I used for years and it only had a little bit left and wasnt sure if I had enough so I needed to know exactly how much it takes. Just wanted to share this piece of info since I wasn't able to find it anywhere. The Ralliart rear diff capacity is somewhere between 650ml to 800ml. I added an extra pump of 150ml fluid after I filled it with 650ml and it started to leak out on me.
Also I'd recommend keep your drain plug clean and apply a thin coat of anti seize on the surface. The hex started to round out on me and I was glad it didn't strip. If anyone has the part number of that drain plug (cannot find anywhere on the internet) or if you know whether the Evo X one would fit please let me know because I wanna replace the plug next time I did the fluid change thanks.
EvoDan2004
154
Apr 2, 2024 01:44 AM
chaotichoax
32
Feb 11, 2020 09:00 PM
Slovak
Jan 10, 2020 09:25 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
runny_yolk
Apr 12, 2004 08:09 PM
Quick Reply: Ralliart driveline fluid change summary with part numbers and torques
