Plasti-Dipped my Front Lip
Plasti-Dipped my Front Ring
Started/finished blacking out my front ring today. Disassembly, spraying, and reassembly took about 6.5 hours, including drying time. The actual assembly took about 30 minutes in total. Took a bunch of pics:
Plasti-Dip
Plastic shielding removed
Bumper removed
Trans cooler
Backside of bumper with screws removed
Front side with ring removed
Ready to spray. Clean the surface well to remove dirt and oil. Do not sand if you're using PlastiDip.
Sprayed, dried and re-installed.
Reassembled
Window trim is up next.
Edit: Here's a few daylight pics
Plasti-Dip
Bumper removed
Trans cooler
Reassembled
Last edited by velocityhead; Jan 28, 2011 at 05:19 PM. Reason: Added a few more finished pics
looks sick!!! did mine tonight but just taped everything off came out pretty good waiting to see how well it holds up... how you thinking about doing window trim?
CESARN..........yes paint the nose-ring.
i think the chrome on the front is distracting and..........cheap looking.
i covered mine with black-out tape the second day i had the car.
it is now covered with satin black vinyl.
Looks great. When I recieve my RA next sat that is the 1st thing I'm doing on sun. I plastidipped my chrome grille on my GTS and it didn't have a single rock chip after 5 months. That stuff is great and easy to remove if u want to remove it or need to redo it eventually.
