How to adjust KW Coilovers
Besides the specifics to your KWs, a great place to advance your learning on how to adjust shocks is the Koni Motorsports web site and catalog. This catalog has some great tips on exactly how to adjust the shocks and even how to select spring rate.
http://www.koni-na.com/pdfcatalogs/K...ortCatalog.pdf
If you can read and understand this catalog, you will know more than most racers. However, even a beginner can utilize the tips and tricks they offer in order to learn how to do simple adjustments on the shocks and get great results, on and off the track.
I installed a set of KW I purchased from Robispec and the first day the car was solid a rock. The suspension was so firm or I would say stiff that I thought something was wrong. After several hours they began to loosen up and by the next day they were perfect. I think that the gas somehow has to acomodate itself until it is working properly . I don't know, but now my KWs work like a dream!
What you experienced is likely 'stiction' caused by the parts not moving freely. In a shock you want the oil passing through the valves to do all the 'work', but when the shocks are new it takes a few miles for all the moving parts to slide easily against each other. With some shocks the stiction never goes away at great detriment to the ride and handling.
clockwise is stiffer
Does this mean that from the top of the strut/car, clockwise means the same direction for both compression and rebound? Meaning, if looking from the bottom, it would be counter-clockwise to increase compression? Thanks!
when adjusting the bump on the V3....do you need to take off the load of the suspension...like raising the car with a jack?
adjusting the rebound and bump:
clockwise = hard/close
counterclockwise = soft/open
is this correct?
is this correct?
guyver858
Dec 31, 2016 04:22 PM
EVO8LTW
Apr 17, 2007 06:07 PM
nick735
11
Apr 15, 2007 12:58 PM
