Help! manifold stud replacement
Exhaust mani right? And you actually broke the stud going into an aluminum head? That's crazy. You're going to have to drill out what's left of the stud from the head. I've heard of some other ways to do it but they elude me at the moment. Google. I would imagine with all the torque put on that stud that the threads in the head are probably also screwed. Helicoil? Re-tap? I feel sorry for you. GL
You have to go to Sears or whatever store you get your tools at and get an "easy out" or "extractor". You would drill a hole in the broken stud, then back it out with the easy out. It comes in a kit with different sized bits and extractors.
http://www.brokentap.com/easy-outs.html
thanks. but my question still is to put a new stud in the block do i just screw it in? or how is it. because i heard from someone that it is casted in and the only way to replace it is to take the whole head off?
They come right out. Make sure you use some loctite on the threads before you install them. Worst thing that can happen is they back out from vibration. And if there's an oil passage behind the hole, your going to have a leak. One of mine popped out and oil got everywhere. Made a nasty mess.
Wait a sec, one or some of the exhaust mani studs double(s) as a plug for the oil circuit? I just did mine as well and I have a hard time believing that. Am I misunderstanding something?
cmillz1225
Jul 14, 2013 07:26 AM
