When to Rotate Tires
Old Apr 19, 2010, 04:04 PM
EvoM Community Team
golgo13's Avatar
Just came back from a HPDE and it occurred to me that I have no idea how long I've had the tires and that I've never rotated them.
What's expected rotation, every 5k? 10k?
Old Apr 19, 2010, 04:05 PM
EVOjuan623's Avatar
6 k miles, every other oil change
Old Apr 19, 2010, 08:50 PM
pao
pao's Avatar
it's fairly subjective as to when you should considering how you drive, how soft of a compound you're using, etc.... but 6k is pretty standard - for example on the oem yoko's i rotated them about every 2.5 kto 3k to keep them even, 3.5K-4K on the neovas, and about every 8k-10k on the bridgestone re96's all season - i swap between the different tires about twice a year
Old Apr 19, 2010, 11:26 PM
EvoM Community Team
golgo13's Avatar
**** lol I'm due.
Old Apr 19, 2010, 11:42 PM
kanyonkid's Avatar
i do lots of spirited driving and hpde's, so i rotate once a week. the fronts always wear(in my case) slightly more then the rear, so rotating as often as i do keeps them even their whole life
Old Apr 19, 2010, 11:45 PM
T2Small's Avatar
If you are running HPDE, I'd recommend rotating them now. Track work will necessitate rotating more often so you don't get uneven wear.
Old Apr 20, 2010, 05:56 AM
Kracka's Avatar
Rotating after every track/autocross event is a good idea.
Old Apr 20, 2010, 08:18 AM
EvoM Community Team
golgo13's Avatar
Will do, thanks guys!
Old Apr 20, 2010, 08:19 AM
MeFryRice's Avatar
I rotate mine with every other oil change. Why not? It only takes a matter of minutes to do...
Old Apr 20, 2010, 08:21 AM
lemmysports2's Avatar
same here.. do mine every other oil change
Old Apr 20, 2010, 01:14 PM
Neal@tirerack's Avatar
We recommend that tires be rotated every 3,000 to 5,000 miles even if they don't show signs of wear. Tire rotation can often be done with an oil change while the vehicle is off the ground.
Old May 5, 2010, 11:15 AM
BoostLover99's Avatar
^ x 2.
Rotated my RE-01Rs with every oil change (3,000 miles) and am approaching 50,000 miles on them with the wear bars just starting to show.
Old May 5, 2010, 11:40 AM
nightwalker's Avatar
I'm heavy on the throttle so I never rotate mine, they wear the same.
Old May 5, 2010, 02:02 PM
EvoIX007's Avatar
I usually route the tires at every oil change. Couple shops around here do it for free, just have to make time for me to go and wait. lol
Old May 5, 2010, 07:22 PM
goldtooth's Avatar
thanks for the reminder
Quick Reply: When to Rotate Tires
