AMS's WICKED 23rr Install pix
I got the car up and running today. Purrs like a kitten. We will be breaking it in and then will put it on the dyno to get another dyno chart which shows what the gains of the motor alone are.
The mods before and after the motor are AMS GT30 kit, AMS VSR intake, GSC S1 cams, AMS turbo back with HFC, AMS FMIC, AMS LIPK, AMS UIPK with Tial BOV, AMS MBC, 880cc injectors with AEM EMS controlling the mix.
The motor is the only thing changed. It went from stock to the 23rr.
Once we get the before / after motor dyno finished, we will be swapping to S2 cams, GT35 turbo and 1000cc injectors.
The car is currently being broken in. Second oil change should happen Monday. After that, I believe it will go on the dyno to see the power gains on the motor. Then is back on the lift for the bigger turbo, cams and injectors.
ITS MONDAY!!!!
I cant wait to see the awesome gains. This is most def the motor that goes into my car when the stocker bites the dust some day. Ive defended this motor time and time again on this forum, now we'll have the data to back it up. Its gonna be sweet.
AMS
AMS
let get some dyno charts from actual people with these new 2.3RR engines. i want to see what these things are capable in real peoples cars. with all kinds of different turbo's from stock to big.
id like to see the spectrum with this engine.
+ 1 on the results, as I can't wait to see what this does with a 35R. Did you consider using the HTA version of the 35R?
Also, what about the Jun MIVEC cams, instead of the S2?
