Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
Stay Tuned! FP Red on E-85 Dyno'd!
Old May 28, 2009, 10:35 AM
WannaRace's Avatar
UPDATE: Page 2, #26
Added Dyno sheet
The time has finally come and my car is complete just the way I've always wanted it. It is a stock appearing 03 Evo with the following mods:
HKS Racing Intake
Buschur UICP
Buschur Deluxe FMIC
AMS LICP
Forge DV
Buschur DP w/ QTP cutout
Hallman Pro RX
HKS 272/272
Headstuds
Buschur Double Pump
FIC 1050cc injectors
Ported/Coated Stock Manifold, 10.5 Hotside, 02 Housing
FP Red w/ HP WGA
Otherwise stock block, head, transmission, etc. etc.
Soon to be tuned by Chris Black @ AMS on E-85
I will have dyno sheets up this weekend if everything works out and I'm not too busy playing around with the car
Old May 28, 2009, 11:27 AM
Evo a Mula's Avatar
what do you think the car will make???
Old May 28, 2009, 11:36 AM
modetm's Avatar
looking forward to seeing the numbers....
Old May 28, 2009, 12:06 PM
TxEvo8's Avatar
500hp/470tq is my guess.
Old May 28, 2009, 12:33 PM
CAD EVO's Avatar
500 whp for sure
Its basically a mini 35r that will be on high boost
Old May 28, 2009, 12:39 PM
toylex's Avatar
YEA i won2 see numbers....
Old May 28, 2009, 01:12 PM
WannaRace's Avatar
I thought I saw a similar setup on AMS' dyno make around 450ish whp.. Don't quote me on that, but I thought I saw that somewhere
Old May 28, 2009, 01:15 PM
*Evil Evo*'s Avatar
ive seen atleast 2 other evos with similar mods and an fpred hit 500whp and 500wtq on E85.. good luck, chris is a badass... i love my E85 tune
Old May 28, 2009, 01:48 PM
Creamo3's Avatar
My guess is 450/450, your injectors might be a limiting factor in how far you're able to push it.
Old May 28, 2009, 01:52 PM
EricJ@AMS's Avatar
I agree with Creamo3. 500whp is definitely out of the question.
Old May 28, 2009, 01:59 PM
WannaRace's Avatar
Thats what I'm expecting, but Eric, is your reasoning because of the injector size as well?
Old May 28, 2009, 02:24 PM
evoWWrs's Avatar
the FP red is good but it doesnt work magic!!! you dont have a huge amount of mods and most arent huge power mods!! 500 on a red would take a built block, better cams...
i believe you will be alright with your injectors with a dual FP... you will have some good numbers but my honest guess would be 420!!
Old May 28, 2009, 02:25 PM
ninekrevs's Avatar
how much boost are you going to run? 500whp is possible if you go past 30psi. although you should of went with 1200cc injectors so you won't run out of fuel.
Old May 28, 2009, 02:46 PM
yahu's Avatar
I'm very interested in this thread. I have similar supporting mods and have been debating which turbo to upgrade to. The FPRed is a front runner, but I don't have e85 readily available but am running 100% meth. Good luck this weekend, OP!
Old May 28, 2009, 02:48 PM
evoWWrs's Avatar
e85 will get you to be able to run around 28 safely...
e85 and pump/meth is practically the same
Quick Reply: Stay Tuned! FP Red on E-85 Dyno'd!
