**Product Release**AMS Mitsubishi Lancer Evolution VII/VIII/IX Dry Sump System
Does the oil drain back thru the system into the sump pan, if the car is left for a few weeks?
I've seen many older D/S systems do this, then needing to be pumped out before starting.
You can mount the tank anywhere in the car. It can be mounted in the trunk, the back seat area, in the front passenger side seat area, in front of the passenger side front wheel behind the bumper. It can be mounted pretty much any where in the car. This is the reason for not including lines and fittings because every application will be different and the mounting will be different.
When we tested and used this system is was for our top shop motor. We have not installed this kit into a vehicle here yet. Here are some pictures of the reservoir being mounted in front of the passenger side tire behind the front bumper. This will give you an idea of how the setup will be mounted. This was a kit that is similar to ours.
boomn29
Jul 8, 2019 05:09 PM
xsesiv
48
Aug 20, 2018 08:49 AM
PRS
Nov 6, 2016 12:33 AM
FS[Northeast]: Ams moroso oil pan -$500
Skidonner90
Jul 20, 2016 07:49 PM
