Evo9 haltech platinum pro plug-in ecu
HALTECH PLATINUM PRO PLUG-IN ECU
2006 Mitsubishi EVO IX
2005-2006 Mitsubishi EVO IX (Euro)
2003-2004 Mitsubishi EVO VIII (RHD Euro)
FEATURES:
Direct plug and play replacement of the OEM ECU, no re-wiring necessary.
Uses the cars factory sensors
Supports Sequential Injection (peak and hold) and Direct fire ignition
Windows 2000, XP, Vista, Windows 7 compatible software
Real time programming, instant hesitation free adjustment while engine is running
Fully user definable 32 x 32 mapping
Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
Diagnostic Trouble Code Storing & Check Engine Light Controll * * (Access through laptop only )
Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
Wideband auto tuning using user definable target AFR table
USB and CAN Communication Port
FACTORY OUTPUTS:
4 x Fuel Injector outputs
4 x Ignition outputs
Tacho , MIVEC Control, Boost Control, Intercooler Sprayer,Idle Control,
Thermo Fan (variable speed), Fuel Pump (variable speed)
A/C Clutch Relay, Check Engine Light
EXPANSION I/O*:
2 x Analogue Voltage inputs
2 x Analogue Temperature inputs
4 x Digital pulsed outputs
*Optional auxiliary harness required to be purchased Haltech Part # HT040003
FUNCTIONS:
Knock Control
Long Term Fuel Trim
ACF On - Base Tables
Closed Loop O2 Control
Decel Cut
Over Boost
Rev Limiter
Closed & Open Loop Boost Control
Gear Setup
Transient Throttle Enhance
CORRECTION TABLES: Fuel Ignition Boost:
Cranking
Air Temp Target Correction
Coolant Temperature Correction
Map Correction
Zero Throttle Gear Correction
Cylinder Trim
TPS Correction
Generic Correction 1*
Generic Correction 2*
Gear Correction
Post Start
Air Temp Duty Correction
Post Start
* Generic Correction tables have user definable axis
MISCELLANEOUS:
Data Logging: 448Kb of onboard data logging, Storage for approx 40 minutes at 10 logs per seconds, 6 channels of data
Max 20 channels logging capability
Tune can be password protected in software
Rugged anodized aluminum casing
POWER REQUIREMENTS:
Source: 8.6 to 16.5 Volts DC
Consumption: 530mA @ 12Volts DC
PHYSICAL DIMENSIONS:
ECU Dimensions Length: 154mm (174mm with MAP nipple)
Width: 158mm Height: 42mm Weight: 680g (1.5 lb)
Applications: Mitsubishi Evolution 9 / Mitsubishi Evolution 8 MR(EURO)
Year Models: 2004 - 2007
Engine Codes: 4G63
Transmission: Manual Only (Automatic not supported)
Factory Functions
Not Supported: Immobiliser
Specification Sheet:
http://files.haltech.com/downloads/p...vo_9_Rev_B.pdf
Quick Start Guide:
http://files.haltech.com//downloads/...V1_Website.pdf
The Platinum Pro Plug-in Mitsubishi EVO 9 Kit includes:
Pro Plug-in ECU, USB Cable, Programming Software CD, Quick Start Guide, Instruction Manual (on CD)
FEATURES:
FACTORY OUTPUTS:
EXPANSION I/O*:
FUNCTIONS:
Knock Control
Long Term Fuel Trim
Decel Cut
Over Boost
Rev Limiter
Gear Setup
Cranking
Map Correction
Cylinder Trim
TPS Correction
Gear Correction
Post Start
Post Start
MISCELLANEOUS:
POWER REQUIREMENTS:
Engine Codes: 4G63
Factory Functions
Quick Start Guide:
I was messing around with the EVO 9 Pro unit today and I must admit I'm very impressed with the results so far. The differences are quite obvious when compared to the regular Sport units in terms of ecu processing speed, control etc.
Going to work with the knock control shortly. Seems like a pretty straight forward setup with a little more options for knock control.
Short & Long Term Fuel Correction on the Haltech EVO9 Pro ECU.
http://www.youtube.com/watch?v=yTiHl...layer_embedded
