Got 1 knock count on Cobb Ap
Old Jan 28, 2013, 07:17 AM
GsrJake's Avatar
So I was viewing the knock count on my Cobb ap while drive and it said 1 knock count. Is this bad? I'm not too sure what this means exactly? Thanks
Old Jan 28, 2013, 07:23 AM
Kracka's Avatar
Absolutely nothing to be concerned about.
Old Jan 28, 2013, 07:25 AM
GsrJake's Avatar
Okay just making sure, thanks man!
Old Jan 28, 2013, 10:43 AM
Panda_stunter's Avatar
1-2 knocks r nothing really, when it's 4 and up, then be worried especially if it's in the same rpm every time.
Old Jan 28, 2013, 05:53 PM
GsrJake's Avatar
could a slippin clutch cause this?
Old Jan 29, 2013, 02:06 AM
Could be a possibility but I highly doubt it. The chatter could be from the transmission, though.
R u tuned on the Cobb OTS maps? Running too rich could also cause knock. The ots maps r rich as hell, I know coz Im using Cobb AP. I'm Using their maps as a base, but I'm tuning it so the afr isn't as rich as their OTS maps. Their OTS maps r running at 10-10.5 afr.
U gotta remember, OTS maps r made to cover a wide array of cars and they have to be on the safe side of the tune...that's why they make the afr so rich.
Old Jan 29, 2013, 08:55 PM
GsrJake's Avatar
no im not im pro tuned with it happend on e85 too
Old Jan 30, 2013, 05:10 AM
MisterHappy's Avatar
Is you clutch slipping?
Old Feb 1, 2013, 05:49 PM
GsrJake's Avatar
yeah bro sometimes
Old Feb 1, 2013, 08:20 PM
hiboost2.0's Avatar
You're fine man. Really 3 and under is fine if it's just randomly...
Typically it's what's called "phantom knock", the knock sensor senses vibrations in the engine assembly if something it out of whack it triggers the knock sensor... Not only that but a lot of "good" tuning software will have an alternate safer ignition and fuel map. At a certain moment if knock ever goes over a certain threshold it will switch to the alternate safer maps until the knock has subsided.
Old Feb 2, 2013, 10:09 AM
DDocto's Avatar
I would log your pulls and see if you have knock then....
Just logged my pulls and I'm going to post up and ask someone to check em out
Old Feb 26, 2013, 08:07 AM
redragin's Avatar
i just logged my car and seems like if i do a second gear pull then i get knock ( 1-4 ) but if i do a third gear or fourth seems like there is alot less knock. is this common?... newbie here
Old Apr 7, 2013, 01:49 AM
mygsx's Avatar
Question
On your 3rd or 4th gear pulls if you are 3 or less you are ok. I know before on my old evo 8 3 and up and the ecu pulls timing, lowers boost, and richens up the afr's until knock goes away. Not sure how it is for the newer X's, I just recently got one myself. Maybe same thing still?
Old Apr 7, 2013, 12:24 PM
btack's Avatar
Good thread.
I see knock between 1-3 on hard WOT pulls sometimes. Doesn't happen on repeated logs at the same rpm range. Definitely seeing 1 count of knock isn't something to worry about. Most likely it is road vibration or shifting vibes.
Tony Harris
Cobb AccessPORT
Mar 12, 2017 07:10 PM
jeffpinto
Apr 16, 2015 04:41 PM
mshilto89
Cobb AccessPORT
Feb 28, 2013 10:12 AM
evofan_08
Oct 29, 2012 03:40 AM
EvoTech
Jul 8, 2005 07:13 AM
Quick Reply: Got 1 knock count on Cobb Ap
