6-7 Knock Count in 5th/WOT: Data logs inside
Old Apr 21, 2015, 05:25 PM
rico05's Avatar
Wanted some input. Not logging AFRs, but according to AEM UEGO between 11.6-12.8:1 when this happens. Only happens during sustained WOT pulls and only in 5th. Two logs attached. Log 1 is from last week, 2 is from today. Similar circumstances/temps.
Wondering if this is what bad/dying fuel pump relay...
Cobb OTS Stage 3 v403. Here comes the flames...
- MAP downpipe
- MAP testpipe
- MAP single
- AEM intake (properly scaled)
- Cobb EBCS
Log 1:
https://drive.google.com/file/d/0B42...ew?usp=sharing
Log 2:
Planning on getting a ProTune soon, just hoping to get E85 setup before hand.
Also, I swapped a green relay in for the fuel pump.
Old Apr 29, 2016, 04:28 AM
RpVilleneuve's Avatar
My car does the same thing. Roll into 5th at a low rpm and the knock gets crazy(logged 10 counts). 5th gear and ots maps must not like eachother. I just make sure to down shift to 4th before getting on it. When I come into 5th from 4th (past 5k rpm) I don't get any knock.
Old Apr 30, 2016, 06:02 AM
rico05's Avatar
Well, for starters, NEVER go WOT in 5th below 4k RPM or so. Lots of stories on the forums about folks putting a rod through the block doing that.
I was having an issue at WOT with knock over 6k or so. I am now ProTuned and no knock.
Old Apr 30, 2016, 07:52 AM
EVL4B11MR's Avatar
Drop a line to Chet Rickerman @ Rickerman Tuning, from what i hear hes great @ figuring things out and he E-Tunes but with Evoscan/Ecuflash.
absolut525
Aug 23, 2016 11:35 AM
stealthMR
Jun 6, 2011 06:56 PM
stunt2
Apr 7, 2011 02:29 PM
jmoudry
20
Dec 31, 2006 08:01 AM
Quick Reply: 6-7 Knock Count in 5th/WOT: Data logs inside
