Evo X Drag Times list
Old May 12, 2016, 09:33 AM
  #316
Fiji_boss's Avatar
Originally Posted by Darksun280
List updated. Good work guys
Forgot to add Tommy Le to the SST list. He should be #13 i believe
Old May 14, 2016, 06:39 PM
  #317
Darksun280's Avatar
complete.
Old May 17, 2016, 12:01 PM
  #318
speedingtwinky's Avatar
Should post up your slip for 2016 list from IFO.
Guess I should post my tx2k slip, since that would put me #1 for 2016....now to find the dam slip lol.
Old May 19, 2016, 11:19 AM
  #319
evo_dean's Avatar
Yea you and Fiji_Boss would both be on the 2016 list.
and Fiji_Boss needs to add Kozmic Tuned on his stock turbo record Kozmic Fam reppin hard.
Old Aug 18, 2016, 08:02 AM
  #320
828evoxMR's Avatar
Took My 2010 Evo X MR to the 1/4 track the pass weekend (8-13-2016)
Here's a link to my Video:
Here's the mod list:
Head work :
Port & Polish Head/3 Angel Valve Job
Kelford 214-B cams
Ferrea Competition 6000 valves (stock size)
Manley spring and titanim retainer kit
ARP 625+ Head stud kit
Cometic 90mm Head gasket
Block :
LA Sleeved
Custom JE 89.15mm 9:1 CR pistons with an anti-friction skirt coating
Manley Turbo Tuff Rod
Manley TurboTuff 94mm stroke billet crank
Cosworth Rod & Main bearings
ARP main studs
Transmission :
SSP Sidewinder Stage 3 (12 Disc)
SSP Internal Filter
SSP External Stainless Steel Filter
Fuel :
ID1700
Radium Fuel Rail
AMS regulator kits
Walbro 255 in-tank
Fuelab 41402-1 (1300hp) Pump
Swirl Forge Surge Tank
-8 Feed
-6 Return
100 micron fuel filter before pump
40 micron fuel filter after pump
Turbo / Exhaust :
ETS Big runner stock replacement Manifold
GTX3582R
Map O2 Dump
Test Pipe
Buschur (bullet muffler) exhaust
Buschur Upper intercooler pipe
Buschur Lower pipe
Buschur 4.5 Intercooler
Sakura 3.5" Intake
Turbosmart Race BOV
-Stock MR Suspension with Swift spring
-Stock Motor Mount
-Michelin Pilot Alpin PA3 tires
-No aftermarket Transmission cooler nor Deep pan
Old Sep 1, 2016, 06:33 PM
  #321
Darksun280's Avatar
Geez I forgot to say I updated the list.
Good work out there 828evoxMR. You're supper close to 10's keep at it!
speedingtwinky stop being a bum and let me know what time and trap to put up there lol
Old Sep 4, 2016, 07:25 PM
  #322
828....~2.35L I see, what fuel are you running? Who tuned the car?
Darkson- sent you what we did in PM.
Old Sep 7, 2016, 09:16 AM
  #323
828evoxMR's Avatar
Originally E98 but due to cold start issues earlier this year. I been adding 30oz of 93 pump gas per 5gal of E98. so maybe E95...
Built and Tune by Motionlab Tuning
Old Sep 7, 2016, 09:20 AM
  #324
828evoxMR's Avatar
Old Oct 18, 2016, 06:27 PM
  #325
Its been awhile since the shootout and we are finally catching up around here, so I wanted to let everyone know the MPH record for an SST and the Stock EvoX/RA ECU has been reset!
Kozmic SST Equipped Ralliart Resets Trap Speed Record doing 9.9@160mph!
Old Nov 7, 2016, 08:00 PM
  #326
Garrett114's Avatar
I ran my 14 GSR over the weekend 12.086. Its a heavy car being fully loaded and I didn't take any weight out. I'm in the right lane.
Mods: AMS STX500 everything else is stock even the Clutch
Old Nov 21, 2016, 04:13 AM
  #327
Mr. Evo IX's Avatar
Car number 216 @ IFO Ennis 11/20/2016
Failure to Launch (due to larger turbo, no launch maps).
Full weight 2013 MR Touring Edition with stock SST clutch pack, stock block, 93oct pump gas, EFR 7670 EWG, GSC S2, ID1000's and Walbro 450.
Old Dec 1, 2016, 06:19 PM
  #328
JohnBradley's Avatar
Improved the E.t. but not the MPH
8.562 @ 158.8 ETS/English/Competition Cutch Caged and Gutted. ETS sidewinder Kit 7285 Gen 2 Turbo, ETS 6.0" FMIC, ETS .V2 Exhaust System, ETS Built Motor Info
Old Dec 6, 2016, 06:49 PM
  #329
the sam's Avatar
Evo X MR
2.2 Nitto stroker, stock frame GTX3582, CBRD manifold, 10 plate built SST by us - BOOSTIN JUICE PERFORMANCE, stock transfer, stock diff, 285 Hankook RS3 all round.
Video is up somewhere but can't find link.
Timeslip:
Old Dec 26, 2016, 02:34 PM
  #330
NY Black momba's Avatar
nice pass 9 second pass for sure!!!
Originally Posted by anasyakoub
here is my 10.472 sec 147 mile run,
did only two runs and couldn't be able to get lower than 1.8 60ft I believe the strip was not good that day, with the same setup I was able to get 1.6
BTW I am using S300SXE now after breaking the EFR9180 on the same Full Race kit
Evo X 10.4 drag race - YouTube
Quick Reply: Evo X Drag Times list
