Top 20 Quickest/Fastest STOCK TURBOS for 2014!
Almost four months into 2014 and no new list so i took the liberty of starting once since ive been to the track a few times already....I will do my best to keep this updated. Following same format as last year!
(not sure how to make this a sticky either so if someone can tell me that would be great!)
Here is a link to the 2013 list/thread:
https://www.evolutionm.net/forums/dr...os-2013-a.html
Please make sure to post timeslip and your information in the following format!!
USERNAME / Date / Main Sponsor / Evo Type / Setup / ET or MPH
2014 Lists:
List 1 (Evo 8 & 9) - BEST E.T. in the 1/4 mile
StockEvo / June 8 2014 / M-tuned&RRT / Evo 9 / Stock evo 9 turbo with bolt ons. Gsc s2 and stock motor / 10.9
XcreatonX/ 8-16-14/ 04 Evo RS/ Bolt ons with 10.5 8 turbo/ 11.423
GreeceS13 / 12.15.2014 / TSCOMPTUNED / EVO 9 MR EU / stock turbo, stock cams, stock ic, 30psi over, semi slick, 95+meth / 11.58
mrm95 / 2.7.2014 / Wingz Performance / Evo 9 RS / Stock block, stock turbo, stock cams on e85 / 11.59
tscompusa 6.15.14 / TSCOMPTUNED / Evo 8 GSR / Full weight, stock block 91oct + meth / 11.613
tscompusa / 5.16.14 / TSCOMPTUNED / Evo 8 GSR / Full weight, stock block 9 turbo E85 / 11.69
1gturbo / 3.22.14 / CBRD / Evo9 MR / Full weight,stock 2L,boltons,e85,25psi,all seasons / 11.78
hppwdn / 1.20.14 / Me / Evo9 / Full weight,stock motor with boltons, stock cams, stock maf, 93 pump gas, 25psi, Street Tires / 12.31
cmspaz / 6/21/14 / RS Motors / Evo IX GSR SSL / panel filter, test pipe, stock tune, stock boost / 13.29
List 2 (Evo 8 & 9) - Fastest MPH in the 1/4 mile
NAME / Date / Main Sponsor / Evo Type / Setup / MPH
StockEvo / June 8 2014 / M-tuned&RRT / Evo 9 / Stock evo 9 turbo with bolt ons. Gsc s2 and stock motor / 124 MPH
XcreatonX/ 8-16-14/ 04 Evo RS/ Bolt ons with 10.5 8 turbo/ 123.62 MPH
tscompusa / 6.15.14 / TSCOMPTUNED / Evo 8 GSR / Full weight, stock block 91oct + meth / 120.32 MPH
tscompusa / 5.16.14 / TSCOMPTUNED / Evo 8 GSR / Full weight, stock block 9 turbo E85 / 119.49mph
mrm95 / 2.7.2014 / Wingz Performance / Evo 9 RS / Stock block, stock turbo, stock cams on e85 / 119.45 MPH
1gturbo / 3.22.14 / CBRD / Evo9 MR / Full weight,stock 2L,boltons,e85,25psi SD tune,all seasons / 117.56 MPH
hppwdn / 1.20.14 / Me / Evo9 / Full weight,stock motor with boltons, stock cams, stock maf, 93 pump gas, 25psi, Street Tires / 111.81 MPH
cmspaz / 6/21/14 / RS Motors / Evo IX GSR SSL / panel filter, test pipe, stock tune, stock boost / 103 MPH
List 1 (Evo 10) - BEST E.T. in the 1/4 mile
05OrangeSS/9-14-2014/STM TUNED/ Evo X/ STM bolt ons, stock longblock, stock turbo, slicks, E85/ 10.96
List 2 (Evo 10) - Fastest MPH in the 1/4 mile
05OrangeSS/9-14-2014/STM TUNED/ Evo X/ STM bolt ons, stock longblock, stock turbo, slicks, E85/ 123.1 mph
List 1 (Ralliart) - BEST E.T. in the 1/4 mile
List 2 (Ralliart) - Fastest MPH in the 1/4 mile
2014 Lists:
I did a 12.3 at Bradenton IFO back in January. Hadn't posted, been trying to get 11s on stock turbo, full weight and 93 pump just for fun.
hppwdn / 1.20.14 / Me / Evo9 / Full weight,stock motor with boltons, stock cams, stock maf, 93 pump gas, 25psi, Street Tires / 111.81mph
Just saw this thread...
Back in February for my first time out i ran a 12.07 @ 119.45 MPH.
Stock block, stock cams, stock turbo, stock intercooler, stock UICP... Just minor bolt ons and E85
INFO:
mrm95 / 2.7.2014 / Wingz Performance / Evo 9 RS / Stock block, stock turbo, stock cams on e85 / 12.07 @ 119.45 MPH
INFO:
is this car gutted? not normal to say "I hope to hit a mid 11" with a stock turbo stock cam and stock IC....that's big MPH for a (assumed) 330-340ish whp car, what boost and injector? what were your hp/tq numbers?
So, I'm gonna be the douche that submits a stock car...
cmspaz / 6/21/14 / RS Motors / Evo IX GSR SSL / panel filter, test pipe, stock tune, stock boost / 13.29 @ 103
With only a 1.9 60' I've got some room to shoot for 12s as the car sits, and will be doing so before the end of the year.
updated, good luck!
roger that. do you have head work and cams? only reason I ask is your specified "stock block" originally. manifold? reason I ask is my car did 388/360 at 25 psi on E with cams and intercooler on a mustang dyno, and did 120mph last fall. sounds like your numbers may be mustang dyno too. I always like to ask about other cars similar to mine. shave 2-4 tenths off your 60 and you will for sure be mid 11s. good luck sir.
