Injector "gunk" and E-85
Old Oct 31, 2016, 09:17 AM
  #256
Klaiceps's Avatar
Originally Posted by dr_latino999
Have a little bit of that on the inside of my injectors, not as bad as his pictures. I'm sending my injectors to FIC tomorrow for testing and cleaning
The gunk or the white oxidation?
Old Oct 31, 2016, 12:28 PM
  #257
dr_latino999's Avatar
The gunk. Didn't mean to play the pronoun game, sorry.
Klaiceps (Oct 31, 2016)
Old Oct 31, 2016, 01:27 PM
  #258
Klaiceps's Avatar
No worry. Thoe99 had white oxidation on his injectors and I almost assumed you had the same issue. Hope everything checks out for your injectors.
Old Oct 31, 2016, 08:37 PM
  #259
kaj
kaj's Avatar
Originally Posted by Thoe99
I have another beater car that I put the high mileage on.
Same here. '00 Civic, A/T, and 35mpg ftw. LOL
Old Nov 4, 2016, 05:44 PM
  #260
Thoe99's Avatar
My injectors got evaluated and cleaned at Precision Turbo. The tech noted, "The injectors are going to come back with a flow sheet to show what the pre and prior cleaning is. The (black) gunk seemed to add material to the internal system so after they were cleaned and that stuff was washed out the flow numbers went down slightly."
Looks like I'll have to re-tune the injector size. I'll post the flow sheets after I get them back soon.
Old Nov 9, 2016, 07:58 PM
  #261
Thoe99's Avatar
I got my injectors back with the flow sheet (below). The good news is that it looks pretty good again with new seals and with improved flow rates. The bad news is that the flow improved a lot on some, but not much on others. So now my variance between the slowest one and the fastest one is 1.9%. I'm not sure if that's significant. My plan is to pair up the slower injectors with the slow flowing banks in the intake manifold (it's oem and not ported). Apparently the unported manifold has slower flowing banks, which is part of why people port them.
So my question is, do you know which banks are the slower flowing ones in the intake manifold?
Old Nov 9, 2016, 08:05 PM
  #262
Thoe99's Avatar
Found out Buschur's tests. Looks like the two closest runners to the timing belt flows the least. Perfect, I'll pair them up with my slower flowing injectors
https://www.evolutionm.net/forums/ev...low-bench.html
Today I spent the majority of the day on the flow bench. The findings were quite interesting.
The numbers below are the cylinder and CFM. All testing was done at 28" on a JKM Flow bench by BRS head services.
Here are the results of what I have found so far.
EVO8 Stock intake, w/stock throttle body:
#4-327, #3-308 (-6%), #2-300 (-9%), #1-300 (-9%), total 1235 CFM
Old Nov 9, 2016, 09:26 PM
  #263
kaj
kaj's Avatar
Found out Buschur's tests. Looks like the two closest ones to the driver flows the least. Perfect, I'll pair them up with my slower flowing injectors
The front of the engine is the timing belt side. Wouldn't that mean the two at the passenger side would flow less? That would make the most sense, being farthest from the TB.
Old Nov 9, 2016, 09:41 PM
  #264
Thoe99's Avatar
Good question, I assumed #4 was the furthest runner from the driver, but you are probably right. I shot Dave Buschur a PM to clarify.
Old Nov 9, 2016, 10:08 PM
  #265
kaj
kaj's Avatar
Yup. Cylinders are counted front to back.
Old Nov 10, 2016, 05:59 PM
  #266
Thoe99's Avatar
Haven't gotten a response from him, but I'll take your word for it. I'll correct my orginal post in case someone else runs into this issue too.
Old Nov 10, 2016, 08:02 PM
  #267
kaj
kaj's Avatar
And my Honda goes the other way LOL (timing belt is on the driver side).
Old Dec 31, 2016, 06:47 AM
  #268
Got my injectors back, almost forgot to post results. These are for 1250 Low-Z.
Original Data Sheet
  1. Injector #1 - 1260cc
  2. Injector #2 - 1260cc
  3. Injector #3 - 1256cc
  4. Injector #4 - 1252cc
  5. Avg Flow - 1257cc
Returned Data Sheet, cleaning not required
  1. Injector #1 - 1302cc
  2. Injector #2 - 1292cc
  3. Injector #3 - 1292cc
  4. Injector #4 - 1295cc
  5. Avg Flow - 1295cc
Old Jan 18, 2017, 06:58 AM
  #269
spoolin turbo's Avatar
I pull my injectors out and spray them down with WD40 to clean them out. I also try and get some pump gas going through occasionally. I went overkill I think and grabbed the 5 or 6 micron filter from fore.
Old Jan 18, 2017, 07:45 AM
  #270
kaj
kaj's Avatar
I use a 10cc syringe. The "straw" from a can of carb cleaner fits in the tip and the injector fits perfectly into the large end. I then force the injector open with a 9v battery and spray the crap out of it. I'll be doing it this weekend, in fact.
I got the idea from a how-to, here on EvoM. 'Works great.
lancerrally45 (Jan 19, 2017)
Quick Reply: Injector "gunk" and E-85
