Stocking E-85 in 55 gallon Drum.....Will it go bad in a period of time??????
Old Jan 30, 2010, 07:07 AM
evovin's Avatar
Question Stocking E-85 in 55 gallon Drum.....Will it go bad in a period of time??????
Im thinking of switching to E85 but the nearest station is like 70 miles from my house
I have two 55 gallon drum and thinking of stocking it. My question is will it go bad after a period of time?
Whats the ideal time limit to stock and use it?(as good as fresh)
thanks
Old Jan 30, 2010, 07:20 AM
Ted B's Avatar
Vin, if you keep the drums tightly closed, you will be ok.
You will need a drum pump. Here is one that should do the job:
Ebay Fuel Drum Pump
Old Jan 30, 2010, 07:30 AM
Steve93Talon's Avatar
Ethanol is highly hygroscopic, meaning it will absorb water from the atmosphere. As Ted said, if you keep the drum sealed it should be ok for awhile.
Old Jan 30, 2010, 08:19 AM
06redrocket's Avatar
they say to keep it off the cement floor due to the various temp changes. U have to get something to put the drums on to keep them off the floor. Plus look into a good pump to get the e85 out of the drums.
Old Jan 30, 2010, 08:56 AM
ripnbst's Avatar
It is a little more viscous than gasoline I belive so you will have to find a pump that will be able to handle it. As far as elevating the drum just put it on top of some 4x4's or 2x4's.
Old Jan 30, 2010, 08:57 AM
0xDEAD's Avatar
I put my 55 gallon drum up on cement blocks. I store it in a barn and so far it has been fine stored 6 months at a time.
Old Jan 30, 2010, 09:31 AM
Lucas English's Avatar
If you keep it sealed you should be fine like others said. Keeping it at a constant temp will also help. The longest I have every kept it in drums is about 6mons and I have seen no problems.
Old Jan 30, 2010, 10:34 AM
Ted B's Avatar
Hand pumps that work for gasoline work for E85 without issue.
Just FYI
Old Jan 31, 2010, 07:41 PM
evovin's Avatar
Thanks guys for all the tip!
Old Feb 3, 2010, 06:34 AM
Gordian79's Avatar
My question is will the gas station sell it to you in 55 gallon drums.From what i gather around here they wont sell it to you unless its going in the car.
Old Feb 3, 2010, 07:35 AM
localtoys73's Avatar
i fill up my car and 4-5 gallon cans in the trunk everytime i go
no issues so far about anyone telling me i cant
Old Jul 23, 2015, 12:16 PM
goodbye's Avatar
I ordered E98 in a barrel several years ago, was actually much cheaper than E85 at the pump. It started going bad about nine months later so I diluted it with fresh pump gas to make roughly E85.
Sorry, just realized I bumped a seriously old thread.
Old Jul 26, 2015, 02:30 PM
Jcros's Avatar
Anymore news on this looking to import and use here on island!
Old Jul 31, 2015, 10:59 AM
94AWDcoupe's Avatar
I bought two used 65 gallon drums from VIGO back when you could get them in 2007-08. I drove five hours to get some e99 to fill them up. I use the e99 for secondary injection. I just started using the second tank a few months ago. still working fine with years of carport storage in very moist florida.
Old Jul 31, 2015, 06:43 PM
mrfred's Avatar
pure ethanol will last much longer than gasoline if kept in an airtight (really artight container).
Quick Reply: Stocking E-85 in 55 gallon Drum.....Will it go bad in a period of time??????
