E85 Gauge w/ output for under $100
Wow I have been looking into doing my own content display recently and I'm glad that I stumbled upon this post. Thanks a lot I will be looking into this once I go FF with my aem infinity. Is that flex fuel sensor that you have linked on amazon the same one/place that you purchased yours?
So the green wire is spliced and has two inputs into the arduino and the pink wire is a separate wire coming straight from the arduino output into the ecu pin? Since this is for stock ecu do you know if an aem infinity will accept that "pink wire" output from the arduino? I read somewhere that people spliced the wire before the arduino to get the signal input for the ecu which may be an unneccesary step for thise setup/case. Sorry if this is confusing, I'm trying to visualize the setup and am a bit unfamiliar
the "green" is going to be your power / flex input wire. The flex input wire MUST be just like it shows, it you place the wire after the resistor, it will not function correctly. The "pink" outputs Hz, not volts
