FF sensor (GM)
Old Nov 28, 2016, 02:59 PM
evo8tanner's Avatar
FF sensor (GM)
There is zero difference in functionality between the GM #13577429 FF sensor and the #13577379/#13577394 sensors other than mounts and sizes correct?
Old Nov 28, 2016, 03:05 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
correct, I use the 13577429 version for everything since it's so much smaller than the other version.
Old Nov 28, 2016, 03:46 PM
evo8tanner's Avatar
Thank you! I will be going with that one as well
Old Jan 21, 2017, 01:58 PM
spoolin turbo's Avatar
Just a different configuration and size. If you are using the adapter fittings get the ones that you screw in. It's a 2 piece thst goes over the hardline. Not the plastic one.
BoostinBird
May 11, 2010 04:17 PM
metaphysical
10
Oct 26, 2004 12:04 PM
areet
Sep 23, 2004 05:52 PM
91_LaserRS
Aug 13, 2004 07:34 AM
MalibuJack
Jul 4, 2004 09:05 PM
Quick Reply: FF sensor (GM)
