Injector scaling
Injector scaling
Hey all,
I'm going to be messing with the injector scaling in ECUFlash and I was wondering if anyone had deadtime/latency/etc charts for different injectors or knew where to look for them?
I am currently using Denso 720cc injectors. I know that the larger injectors usually scale differently depending on RPM and load because of deadtime so I know just inputing "720" into ECUFlash probably won't be the perfect solution.
Anyone have any thoughts / ideas / comments on this?
This actually came up in conversation last night.. There's a Injector Voltage Compensation, and a scaling, Stock injectors are approximately 550cc, in the ECUFlash it shows it as 513, I'm guessing you would eyeball your sizing, look at the fuel trims until your within +/- 10% If you just can't get big injectors to idle well, then you would adjust the voltage compensation so you can compensate more for slightly lower voltage (idle speed)
I think there are other compensation settings that didn't make it into the Definitions yet.
I believe ECUtek has it.
i would have never thought of using the voltage compensation to help with the idle on large injectors.
goofygrin
36
Jun 27, 2017 11:17 AM
4RETECH
Apr 11, 2013 11:52 AM
