Engine Coolant Temp...
Im still learning here. My question is at what point does engine coolant temperature play a role ( if any)? Does the ECU make timing changes if you are running over a certain temperature ( above normal)? What about on a cold engine? i could be way off though.
The only coolant temp related items I currently see defined are
min coolant temp for closed loop (in celcius)
That does not mean there aren't more, in fact, there are probably several in the ECU's rom, only they have not yet been defined in the program.
Give it time, it will eventually be documented as its found or added.
In the past, I haven't specifically noticed any changes due to high coolant temps, but I also have not run my car in conditions that could cause it.
You are very wrong on this point
Remember - the "definitions" you are looking at are only a small handful of what can be adjusted in the raw code.
Anyone with an a/f gauge will be able to quickly determine what role coolant temprature plays in an evo - a rather HUGE role
In Evos the a/f goes very rich as the coollant temps rise above 185 degrees - as you get hotter the car goes richer and richer
How could I be wrong when I said
1) The only one defined currently is the "min coolant temp for closed loop" item
2) That I had not observed anything different because I have not yet run my car in conditions that would cause it to run very hot?
I am aware of a few additional addresses and tables that are not yet published in this software.. but since I do not know enough about them, I am waiting until they are published in the XML Definitions.
Originally Posted by DynoFlash
[You are very wrong on this point
??? Al you need to read the posts more.
Location: City O Sin, MA...the not so sinish part though...
The boost control solenoid has a coolant temp trim. It will only allow 10 psi when your engine is cold, then 15 as its warming up, and full boost when at operating temp. Obviously this is not relevant if your running an aftermarket boost controller.
Originally Posted by l2r99gst
The DSM ECU pulls timing when the coolant temps rise, too. IIRC, it is 1 degree at 206 and goes from there. I forgot the temp at which 2 degrees are pulled.
Eric
Eric
These things will start turning up as the XML definitions get updated.. I have to assume that I'll hear about some of these as their found I should be able to talk about them as they determine the data does what it seems.
Jmills
Dec 26, 2015 08:25 AM
pkevoIXMR
Oct 8, 2013 05:29 AM
dbdude
Jun 11, 2006 04:17 PM
