What is the max load are u seeing guys?
#290
1 Post
[QUOTE=jcsbanks;6530449]96260009:
<table name="Set to 9 to remove load limit" address="25d40" type="1D" level="1" scaling="Hex16"/>
does anyone have the code to remove the fuel limit on 96260009 too? I have a 3794R car that's going to go way over 380 soon.
#292
this is everything in my notes folder
96940011: <table name="Set to 9 to remove load limit" address="28140" type="1D" level="1" scaling="Hex16"/>
94170008/94170015: <table name="Set to 9 to remove load limit" address="26592" type="1D" level="1" scaling="Hex16"/> <table name="Set to 9 to remove fuel limit" address="265AE" type="1D" level="1" scaling="Hex16"/>
96260009: <table name="Set to 9 to remove load limit" address="25d40" type="1D" level="1" scaling="Hex16"/>
90550001: <table name="Set to 9 to remove load limit" address="22014" type="1D" level="1" scaling="Hex16"/>
96530006: <table name="Set to 9 to remove load limit" address="27824" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 9 to remove IPW limit" address="27926" type="1D" level="1" scaling="Hex16"/>
88840017: <table name="Set to 9 to remove load limit" address="2901a" type="1D" level="1" scaling="Hex16"/>
85590015:
<table name="Set to 9 to remove load limit" address="2a49c" type="1D" level="1" scaling="Hex16"/>
<table name="Set to 9 to remove IPW limit" address="2a69a" type="1D" level="1" scaling="Hex16"/>
see what other rom 96260009 inherits and most likely will be the same IPW limit removal
85590015:
#296
1 Post
that looked correct in the ROM so I set to 9 but didn't see a change in the AFR. It's possible that we aren't far enough above 380 to make a difference yet. Thanks for sharing that.
#299
Looking for confirmation of the load cap and fuel cap address for 88570008 please.
I have 2C9FC and 2CA0A but nothing to confirm they are correct.
The correct address were sent to my by Donner and are:
263F4 Load
266D6 IPW
263F4 Load
266D6 IPW
