HOW TO - Control boost using ECUFLash and 3 port GM boost solenoid
I just installed my GM solenoid I had left over from my AEM setup on my old car yesterday. Unfortunately I left the pigtail wired to the old car(Ordered another already) Temporarily I used some terminal connectors, the smallest ones I could find that fit into the harness portion of the solenoid. It did take less duty cycle than before as already mention, but I tried the settings razorlab posted in one of the previous links and could only get about 18psi with no pills. Now it has been adjusted and I am getting 21psi all the way to redline according to the gauge. The car does spool slightly faster, actually noticeable. I am going to put a pill before the turbo and see how that goes.
I was thinking of going with a straight ECUflash with the XEDE acting like a pass-through unit only running such things as conditionals like lean-run protect and possibly SMART, but I'm not sure on that.
As of right now, I don't know how to switch maps with the stock ECU (getting a 100map too). I keeping reading the ECUflash forum, but a lot of it I don't really understand yet
I don't use any pills with the GM boost solenoid. I have run up to 31 peak psi and held 25psi on the street with no pills. This is on a FPgreen.
On stock turbo I have run up to the same peak psi and 22 psi held on the street.
I haven't messed with pills yet. I have actually been curious if it would actually mess with the resolution and response of the unit since its a interrupt type device. I really haven't put much more thought than that into it with pills since they work so well without them so far.
mchuang, what WGDC are you using up top to achieve 21psi?
I have a couple of wierd issues also. I notice you guys stating that your wastegate duty cycle is 0 at idle. My wgdc shows 100 and as I begin to boost it drops down. This is before and after the GM Solenoid install. This was in evoscan, and I changed nothing in the xml. Anyone know why that could be? The other wierd thing, I noticed you stated something about tuning without error correction, so I turned it off and got 19-20psi(gauge reading lower than normal) I turned it back on and it read 21psi.
