How To Tune an Evo
Old Nov 8, 2015, 09:01 PM
  #841
kaj
kaj's Avatar
Originally Posted by Raptord
Oooooh. That's new to me. Will read! Thanks.
Old Nov 9, 2015, 03:51 PM
  #842
Raptord's Avatar
It's been in my sig for a couple years man, open your eyes!
Old Nov 9, 2015, 04:37 PM
  #843
kaj
kaj's Avatar
The mobile app doesn't show sigs.
Old Dec 11, 2015, 10:08 AM
  #844
ZanarkO's Avatar
mmm did that mom ever get her sons evo str8? And there should be a sticky on the site about the EVO IX's and EVO X's and that ecu reflash recall lol. I have had a few customers with EVO IX's get the airbags replaced and the dealer ALSO performed the ecu recall and there tunes are gone and the dealer cant figure out why the cars wont start anymore *sigh*
Old Dec 11, 2015, 11:52 AM
  #845
Klaiceps's Avatar
Interesting. I've had to bail out our local Mitsubishi dealership a couple times due to the ECU recall they performed on Evo IX's. Luckily the cars I flashed were stock and not modified.
Old Dec 11, 2015, 11:56 AM
  #846
kaj
kaj's Avatar
my dealer service rep left my ECU alone, but marked that it was done so i have no issues come smog time.
Old Apr 25, 2017, 06:29 PM
  #847
leemaster's Avatar
HELP!!!
So, i installed EcuFlash on my laptop, and then I connected the tactrix cable onto my car. I clicked on the "Read from rom" thing. and then after the laptop read "unknown rom", my car could no longer start. WTH!?
I didnt do anything, didnt change any parameters or anything. just logged on and now my car no longer starts. what happened!?!?!? Tried disconnecting the battery, car wont start, tried taking out the ECU / battery fuse, still wont start.
It cranks, but wont start. HELP!!!
EDIT: I did the "test write rom into ECU", i was messing around with it a little bit. I didnt think it would cause so much issue, how do I reset it back to my old rom settings?
Old Apr 25, 2017, 07:32 PM
  #848
kaj
kaj's Avatar
The immobilizer code most likely no longer matches the car. Flash your stock rom, change the code on the current one, or disable it completely.
Old Apr 25, 2017, 10:10 PM
  #849
leemaster's Avatar
would it mess with the tune if i flash it stock?
Old Apr 25, 2017, 11:23 PM
  #850
kaj
kaj's Avatar
Yes. It would then be stock.
Old Apr 26, 2017, 07:11 PM
  #851
leemaster's Avatar
**** I have an E85 tune with E85 in the tank. Any other way I can keep the tune? It didnt even give me an option to load my tune and save it in a folder. Or is there a way to do that which I didnt know about? There was no option for that if I recall. I only wanted to adjust my IPW settings but didnt want to **** with anything else
Old Apr 26, 2017, 08:02 PM
  #852
kaj
kaj's Avatar
- You can read the ROM from the ecu and save it to a folder, yes.
- It gave you the option to save, you just needed to save it. If you mean it didn't prompt you, then no: it doesn't. The program assumes a certain level of knowledge. You should know how to use it before you do.
- You may want to have someone who knows what they are doing fix it before things get worse.
- I suggest reflashing your original tune, before you messed with it. It sounds like your tuner has your immobilizer set correctly.
- Count your blessings: you could have bricked your ECU. Definitely could have been worse.
Hit up Gary Bains @ Bains Tuning. He's a good dude, responds quickly, and can fix ya right up. His link is in my signature.
Old Jun 25, 2017, 11:16 PM
  #853
nathantk94's Avatar
Does anyone have the images from the thread? All the images appear to be broken.
Old Jul 11, 2017, 02:49 AM
  #854
Acuality's Avatar
I am looking for the same if anyone has them, thanks
Old Oct 28, 2017, 12:34 PM
  #855
Evo8life's Avatar
New to tuning i have read my rom from ecuflash just to check it as the car is already tuned
Do i need to write the rom back if i didnt made any changes
The car starts fine anyhelp would be greatly appreciated
Quick Reply: How To Tune an Evo
