tuning percision 780s
Old Jan 14, 2008, 07:26 PM
SlowSportSedan's Avatar
does anyone have a good scaling and latency for precision 780's
everything seems to check out well.. but im getting a really rich spot from 1-2k and so/so gas mileage... stock injectors iwas getting 200ish a fill up, now im getting 170ish... this is me staying out of boost... just having a little fun...
i have stock latency with a 713 scaling
when i use the reccomended aem latency it screws everything up
my mid high and low trims seem very very consistent... but my o2 feed back is all over the place from -15 to +15
ive played with them the best i can and the stock latencies seem to be working best
thanks in advance
Old Jan 14, 2008, 07:37 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
You cannot use stock latency values on aftermarket injectors.
Hint, try adding more latency at 14v
Old Jan 14, 2008, 07:47 PM
i've tried from stock up to .96 and its not doing much... i understand it takes about 10-15 min of logging to see changes.. bah!
thank you for responding razorlab
Old Jan 14, 2008, 08:56 PM
cpoevo's Avatar
use these and see how they work out. I know of at least 4 people that are using them and they work great.
This is for the PTEs 780.
4.69 3.504
7.03 2.184
9.38 1.224
11.72 0.96
14.06 0.744
16.41 0.552
18.68 0.432
injector scaling 696
Old Jan 14, 2008, 10:05 PM
ive tried those and i was getting some bad lean spots and some bad rich spots... the car just isnt responding..... bah so much for learning how to tune
Old Jan 15, 2008, 02:32 AM
awadkhan's Avatar
yeah
m gettin the same thing with 780z pretty lean spots AFR go neat to 11z and suddenly it jumps upto 12-13 fer a millisecond thn again to 11s... wat the heck is that....
Old Jan 15, 2008, 11:32 AM
RazorLab's Avatar
when are you guys getting it jumping around like that? at idle or somewhere else?
Old Jan 19, 2008, 08:01 AM
EvoM Moderator
joedr's Avatar
Sudden dips/releases in gas pedal can lead what you are describing!
Please post some logs whent that is happening so they can be analyzed.
Old Jan 21, 2008, 06:17 AM
awadkhan's Avatar
hmmm
its at WOT ....
Old Mar 9, 2008, 03:28 AM
EvoM Moderator
joedr's Avatar
Thumbs up
If the AFRs oscillate that bad, it may be something wrong with the tune.
Can you post your High Octane Fuel Map?
Originally Posted by awadkhan
its at WOT ....
Fast_Freddie
Oct 30, 2023 01:56 AM
mrfred
Apr 21, 2013 09:37 PM
dubbleugly01
Dec 23, 2006 01:52 PM
ballistic speed
Dec 16, 2006 10:29 AM
Quick Reply: tuning percision 780s
