Highest whp on stock ECU
Old Aug 7, 2008, 01:24 PM
  #61
AWD Motorsports's Avatar
I know Jestr has made in the High 500's at a local mustang dyno here before.. That guy can really tune stock ecu very well.. Every car i have seen him tune not only makes power but it runs well at the track!!
Old Aug 8, 2008, 12:47 AM
  #62
JohnBradley's Avatar
Originally Posted by dudical26
that should provide some good info. I remember David made a comment about some of the motors he has built are noisy and other ones are not....I wonder how the stock ECU will respond.
Its really odd how that one works.
You can take 2 identical motors, set the up with piston to wall thats .003-.004 and it will sound like a diesel when its running and then take and set up a looser motor at .005-.006 and its as quiet as stock.
Then on top of it neither seem to make any knock that you wouldnt expect under WOT, but will part throttle knock like a son of a gun.
dunno, but sometimes I really wish the knock was load definable and rpm definable.
Old Aug 8, 2008, 06:42 AM
  #63
dudical26's Avatar
Yea its really odd. I tried to tune my friends car which had a built 2.3 and I just couldn't do it. It was always getting knock no matter what I did. We tried race gas and it just didn't matter. The motor was so damm noisy. Knock controll on and off below certain loads and RPM's sounds easy enough to impliment. But I think thats more of a temporary fix. To compete with standalone, the stock ECU's knock algorithim will really have to be completly tunable.
Have you ever tried playing with the knock filters?
Old Aug 8, 2008, 06:44 AM
  #64
gmore84's Avatar
Originally Posted by Duby
Just as the title says, I've searched and found slightly over 500 done on the stock ecu. What is the highest some one has put down. no gm maf... stock MAF and ECU- thanks
good question.
Old Oct 31, 2008, 09:23 PM
  #65
Mellon Racing's Avatar
bringing this thread back...
93 octane, no meth, alky or water etc..
stock ecu and mas with full honeycomb glued in
full weight car with tools in the trunk
10.41 @ 135 should be over 600awhp
https://www.evolutionm.net/forums/sh...d.php?t=378737
Old Oct 31, 2008, 11:25 PM
  #66
video http://www.racevideoforums.com/forum...k-ecu-mas.html
Old Nov 1, 2008, 06:11 AM
  #67
dan l's Avatar
Have you ever listened to a motor using a microphone and headset? Its quite an eye opening experience. I've noticed that motors, especially built ones are extremely noise during low load low rpm conditions. Upon higher rpm and boost conditions the motor tends to quiet down. It gets to the point where it almost sounds sewing machine smooth once you tune it in well. I encourage you to built your own microphone/headset setup and give it a try yourself.
Old Nov 1, 2008, 06:20 AM
  #68
Nomad4g63's Avatar
Isn' this the highest horsepower on stock ecu evo
http://www.youtube.com/watch?v=q7FEKko6_Bo
Old Nov 1, 2008, 06:31 AM
  #69
yes, using c16 I think it is but I'm on 93 octane...I wonder if that car ever hit the track.
just looked at the mod list....850cc injectors and SAFCII
http://www.mooremaxperformance.com/2003_evo_viii.htm
Old Nov 1, 2008, 06:47 AM
  #70
dan l's Avatar
I think that's a cool car because the setup is so old school.
Old Nov 1, 2008, 08:11 AM
  #71
ONRAILS's Avatar
that isn't the record holding car.
i know a car put down 689
on nitrous
Old Nov 1, 2008, 08:44 AM
  #72
oldevodude's Avatar
It sounds like you want to just enjoy your recent investment in parts. Sure not getting 100 percent out of it is not cool but you can drive it with a more conservative tune on the stock ecu and maf and then wait/save until you can get a stand alone. buying a possible temporary solution will just cost more in the end. If it were me I would run what I have knowing it will be limited possibly and then save my pennies and buy a solution that is known to work. AEM would be ECU of choice simply due to the raw numbers of evo's that have successfullyl run it,the numbers of tuners available and the feedback you could receive based on others experiences
Grats on the build and good luck
Old Nov 1, 2008, 09:21 AM
  #73
Jack_of_Trades's Avatar
Everyone is so quick to burn money on that damn AEM. Read up on where they are with the stock ECU, you'll be amazed how quickly its catching up to the AEM Pro. Mellon already has an AEM Pro sitting in his garage too but I don't think he'll need it anytime soon.
Old Nov 10, 2008, 05:59 PM
  #74
I'm about ready to sell the AEM EMS...I just don't think I need it.
Old Nov 10, 2008, 06:34 PM
  #75
dan l's Avatar
The other nice thing about the stock ecu is that you have to actually try to hurt a motor with it. Well that is until you redo the code in it such that the knock sensor is ignored and you jack the timing up all the while experiencing a fuel pump failure. Ask me how I know.
http://i298.photobucket.com/albums/m...incylinder.jpg
Quick Reply: Highest whp on stock ECU
