PATCH: TephraMod V5
Old Mar 18, 2008, 05:53 AM
  #31
bnice01's Avatar
I should be able to test 94170014 this week or weekend on my buddies car I just have to install a new t-case first. Everything looks good in ecuflash
Originally Posted by Jack_of_Trades
Yeah my pre-made harness' have the 4.7v
sweet payment sent, i'm lazy LOL
  #32
Youngsyr's Avatar
Any chance of adding V5 to 93660005, please?
I think this is a fairly common JDM Evo 8 Rom.
Old Mar 18, 2008, 06:08 AM
  #33
cossie1's Avatar
90550001 can be confirmed as working 100% unless you have made any changes since the last beta test you sent out.
I've tested ADC0F map switching, and high / low knock, and the valet mode, barryc has tested the AutoICS map switching and NLTS
Old Mar 18, 2008, 06:15 AM
  #34
MR Turco's Avatar
Tephra what is "fresh ignition"?
Old Mar 18, 2008, 06:23 AM
  #35
cossie1's Avatar
It's to do with the valet mode.
If you set it to activate with fresh ignition, it means everytime you turn the engine off, it will auto set the valet mode on again.
So if you use it like an immobilier like I do (set at 300rpm) then when you leave the car, you don't have to sit there for xxxx amount of seconds to reactivate it
Old Mar 18, 2008, 06:28 AM
  #36
MR Turco's Avatar
yeah but then dont you have to deactivate it everytime you get back in your car?
Old Mar 18, 2008, 06:30 AM
  #37
cossie1's Avatar
Yes you do, thats why there is the option to have it set on fresh ignition
Gives you the option to manual activate and deactivate when you want, or have it auto set, and then manual deactivate when you get in
Old Mar 18, 2008, 06:32 AM
  #38
MR Turco's Avatar
Ah gotcha!
  #39
bnice01's Avatar
Originally Posted by ciobing
is it possible include the 2byte load in the V5?
https://www.evolutionm.net/forums/sh...d.php?t=327185
Old Mar 18, 2008, 06:38 AM
  #40
Jack_of_Trades's Avatar
Pre-made harness' will ship out tomorrow morning for everyone who ordered one today, Post office is always closed before I get out of work so I will drop them off first thing in the a.m.
Old Mar 18, 2008, 06:40 AM
  #41
Adamantium's Avatar
Dave/Tephra,
you mentioned that the JDM patch is coming soon, does that mean it is at the head of the queue, also have you looked at compatibility with John Banks live mapping features yet?
Old Mar 18, 2008, 06:43 AM
  #42
jcsbanks's Avatar
Once Dave makes 88570008 available I'll patch it with live mapping and then test. I'll then send Dave a live mapping version of his own ECU for him to test.
Old Mar 18, 2008, 06:56 AM
  #43
MR Turco's Avatar
I would be happy to test as well John if you need more people.
Old Mar 18, 2008, 07:00 AM
  #44
Deus's Avatar
Since this is such a large change to the code of the ROM, I figure I'll ask. Does this change the ability to use the JDM 3 bar map? Or are all the locations for things to change still the same for that feature?
And just because a shout-out is deserved... Tephra, you are THE man!!!
Also, anyone else that is involved in the ECU disassembly and changes, thank you. You guys are amazing.
Old Mar 18, 2008, 07:02 AM
  #45
MR Turco's Avatar
You will need to move all the table values you have edited to the new patched rom. The JDM map changes dont require anything but new values.
Quick Reply: PATCH: TephraMod V5
