how-to: airflow rate in gm/s or lb/min and mpg
Old Oct 14, 2008, 10:07 PM
mrfred's Avatar
Introduction
I recently decided it would be kinda nice to be able to log airflow rate in gm/s or lb/min so that it would be possible to log mpg. There is an algorithm for OBD-II diagnostics (recently found by acamus) that calculates temperature and baro corrected airflow rate in gm/s. I was hoping that we could log this value with EvoScan, but there was no easy way to log it with EvoScan. I checked around in the code and found that its calculated in several other places, but the algorithms are not in the main loop, so the ECU performs the calculations very infrequently. That left the final alternative of writing a patch which I just finished and tested this afternoon. Its working perfectly for my 88590015 ROM. Don't know when I'll get around to porting it to other ROMs, but at least its available for the 88590015. This patch is compatible with all tephra 88590015 ROMs.
The output from the algorithm is a 2-byte airflow rate and also a 1-byte airflow rate. I've only logged the 2-byte value as it will be much more precise than the 1-byte value.
After the patch is applied, the following items can be logged:
airflow rate in lb/min
mileage in mpg for either gasoline or E85
I can't say anything about the accuracy of the airflow rate except that it exactly matches the value produced for OBD-II diagnostics. I can say, however, that my initial mpg logs are damn close to what I expected for my overall mileage. It should be very handy for fine tuning daily driver performance and optimizing driving technique for mileage.
Instructions
There are three basic steps:
1) Copy some definitions to your ECUFlash 88590015.xml file. The definitions are below.
2) Launch ECUFlash and copy table data from a base ROM to your ROM. The base ROM can be downloaded here.
3) Add some entries to your EvoScan Data.xml file. The entries are below. Add the entries that you prefer. Note that to log mpg, both "speed" and "AFRMAP" need to be logged as well. Its also possible to get mpg using wideband AFR data as well. This would be the preferred method for open loop conditions, but it will bounce all over the place during closed loop cruise because of closed loop feedback. If you want to use wideband AFR data instead of AFRMAP, then replace "AFRMAP" in the mpg definition with whatever LogReference value you have for your wideband data definition.
Entries to add to your ECUFlash "88590015.xml" file
------ (Don't copy the "-------")
<table name="Airflow Rate Calc On/Off" category="Airflow Rate Meas" address="873E" type="1D" level="1" scaling="uint8"/>
<table name="MUT46 (Read 2-byte airflow rate high byte)" category="Airflow Rate Meas" address="3ef9e" type="1D" level="1" scaling="Hex16"/>
<table name="MUT47 (Read 2-byte airflow rate low byte)" category="Airflow Rate Meas" address="3efa2" type="1D" level="1" scaling="Hex16"/>
<table name="MUT48 (Read 1-byte airflow rate)" category="Airflow Rate Meas" address="3efa6" type="1D" level="1" scaling="Hex16"/>
<table name="0x80 for Airflow Rate" category="Airflow Rate Meas" address="8744" type="1D" level="1" scaling="uint16"/>
<table name="Airflow Rate Patch ROM Addr" category="Airflow Rate Meas" address="1780c" type="3D" level="1" scaling="Hex16">
<table name="Code" type="Static X Axis" elements="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="2">
<data>1780C</data>
<data>1780E</data>
</table>
</table>
<table name="Airflow Rate Patch Part 1" category="Airflow Rate Meas" address="47e80" type="3D" level="1" scaling="Hex16">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="40">
<data>47E80</data>
<data>47E82</data>
<data>47E84</data>
<data>47E86</data>
<data>47E88</data>
<data>47E8A</data>
<data>47E8C</data>
<data>47E8E</data>
<data>47E90</data>
<data>47E92</data>
<data>47E94</data>
<data>47E96</data>
<data>47E98</data>
<data>47E9A</data>
<data>47E9C</data>
<data>47E9E</data>
<data>47EA0</data>
<data>47EA2</data>
<data>47EA4</data>
<data>47EA6</data>
<data>47EA8</data>
<data>47EAA</data>
<data>47EAC</data>
<data>47EAE</data>
<data>47EB0</data>
<data>47EB2</data>
<data>47EB4</data>
<data>47EB6</data>
<data>47EB8</data>
<data>47EBA</data>
<data>47EBC</data>
<data>47EBE</data>
<data>47EC0</data>
<data>47EC2</data>
<data>47EC4</data>
<data>47EC6</data>
<data>47EC8</data>
<data>47ECA</data>
<data>47ECC</data>
<data>47ECE</data>
</table>
</table>
<table name="Airflow Rate Patch Part 2" category="Airflow Rate Meas" address="47ed0" type="3D" level="1" scaling="Hex16">
<table name="Code" type="Static X Axis" elements="1">
<data>Hex16</data>
</table>
<table name="Address" type="Static Y Axis" elements="24">
<data>47ED0</data>
<data>47ED2</data>
<data>47ED4</data>
<data>47ED6</data>
<data>47ED8</data>
<data>47EDA</data>
<data>47EDC</data>
<data>47EDE</data>
<data>47EE0</data>
<data>47EE2</data>
<data>47EE4</data>
<data>47EE6</data>
<data>47EE8</data>
<data>47EEA</data>
<data>47EEC</data>
<data>47EEE</data>
<data>47EF0</data>
<data>47EF2</data>
<data>47EF4</data>
<data>47EF6</data>
<data>47EF8</data>
<data>47EFA</data>
<data>47EFC</data>
<data>47EFE</data>
</table>
</table>
Definitions to add to your EvoScan "Data.xml" file
If you want to log in lb/min, use these definitions:
<DataListItem DataLog="N" Color="" Display="Airflow Rate lb/min" LogReference="lbamin" RequestID="46" RequestID2="47" Eval="0.00312*x" Unit="lb/min" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage Gasoline" LogReference="mpg" RequestID="CALC" Eval="5.9*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage E85" LogReference="mpge" RequestID="CALC" Eval="4.18*[Speed]*[AFRMAP]/[lbamin]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
If you want to log in gm/s, use these definitions:
<DataListItem DataLog="N" Color="" Display="Airflow Rate gm/s" LogReference="gmas" RequestID="46" RequestID2="47" Eval="0.0236*x" Unit="gm/s" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage Gasoline" LogReference="mpg" RequestID="CALC" Eval="0.78*[Speed]*[AFRMAP]/[gmas]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="Mileage E85" LogReference="mpge" RequestID="CALC" Eval="0.552*[Speed]*[AFRMAP]/[gmas]" Unit="mpg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="10000" ChartMin="0" ChartMax="10000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Oct 14, 2008, 10:10 PM
mrfred's Avatar
Here's a road dyno log showing airflow rate in lb/min along with whp, torque, boost, and AFR.
Attached Thumbnails how-to: airflow rate in gm/s or lb/min and mpg-airflowrate_evo9.gif
Old Oct 14, 2008, 10:12 PM
mchuang's Avatar
Wow nice, some people are too dam smart :P
Old Oct 14, 2008, 10:24 PM
tephra's Avatar
good on ya - I was just trying to work out how to convert Hz to lb/min as well
Old Oct 14, 2008, 10:35 PM
mrfred's Avatar
Working out the details was a bit more of a PITA than I though it would be considering how simple the calc is. Calc from the OBD-II subroutine is below. My calc is a bit quicker as I avoid using long division. You are welcome to add it to your next tephra ROM series if you want.
Code:
ROM:0003AA34                 mov.l   @(h'D4,pc), r10 ; [0003AB0C] = unk_FFFF6C74 ; airflow per Hz
ROM:0003AA36                 mov.w   @r10, r10
ROM:0003AA38                 extu.w  r10, r10
ROM:0003AA3A                 mov     #h'76, r11 ; 'v' ; 0x76, #118 -> r11
ROM:0003AA3C                 mulu    r10, r11
ROM:0003AA3E                 sts     macl, r2        ; airflowrate*#118 -> r2
ROM:0003AA40                 mov.l   @(h'C4,pc), r10 ; [0003AB08] = unk_FFFF6C7E ; 0.625*baroADC
ROM:0003AA42                 mov.w   @r10, r10
ROM:0003AA44                 extu.w  r10, r10
ROM:0003AA46                 mov.l   @(h'BC,pc), r11 ; [0003AB04] = unk_FFFF6C7C ; air temp compensation
ROM:0003AA48                 mov.w   @r11, r11
ROM:0003AA4A                 extu.w  r11, r11
ROM:0003AA4C                 mulu    r10, r11
ROM:0003AA4E                 sts     macl, r12       ; 0.625*baroADC*airtempcomp -> r12
ROM:0003AA50                 mov.l   @(h'AC,pc), r4 ; [0003AB00] = unk_FFFF6B9E ; 2-byte MAF Hz
ROM:0003AA52                 mov.w   @r4, r4
ROM:0003AA54                 extu.w  r4, r4
ROM:0003AA56                 mov     r12, r5         ; 0.625*baroADC*airtempcomp -> r5
ROM:0003AA58                 mov.l   @(h'A0,pc), r10 ; [0003AAFC] = sub_EEE
ROM:0003AA5A                 jsr     @r10 ; sub_EEE  ; r4 * r5 -> r0
ROM:0003AA5C                 nop
ROM:0003AA5E                 mov     r0, r4          ; MAFHz*0.625*baroADC*airtempcomp -> r4
ROM:0003AA60                 mov     r2, r5          ; airflowrate*#118 -> r5
ROM:0003AA62                 mov.w   @(h'56,pc), r6 ; [0003AABC] = h'1900 ; #6400
ROM:0003AA64                 mov.l   @(h'90,pc), r10 ; [0003AAF8] = sub_5E8
ROM:0003AA66                 jsr     @r10 ; sub_5E8  ; r4*r5/r6 -> r0
ROM:0003AA68                 nop
ROM:0003AA6A                 mov     r0, r4          ; airflowrate*#118*MAFHz*0.625*baroADC*airtempcomp/#6400 -> r4
ROM:0003AA6C                 mov.l   @(h'84,pc), r10 ; [0003AAF4] = sub_86A
ROM:0003AA6E                 jsr     @r10 ; sub_86A  ; shlr16 r4 -> r0, i.e., r4/65536 -> r0
ROM:0003AA6E                                         ; (shift right 16 bits [1 word])
ROM:0003AA70                 nop
ROM:0003AA72                 extu.w  r0, r1          ; airflowrate*#118*MAFHz*0.625*baroADC*airtempcomp/(#6400*#65536) -> r4
ROM:0003AA72                                         ; 1.758e-07*airflowrate*MAFHz*baroADC*airtempcomp -> r4
Old Oct 15, 2008, 04:21 AM
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
mrfred, Thank you for the credit.
So it seems you actually have got time to look at OBDII part.
What about mode 6 tid 7?
Old Oct 15, 2008, 06:22 AM
l2r99gst's Avatar
Awesome. When I get some time, I will port this to 96940011. I'm a bit busy this week, so it should be next week sometime.
Eric
Old Oct 15, 2008, 06:51 AM
mrfred's Avatar
I'll spend the next couple weeks on that. :-)
Old Oct 15, 2008, 09:39 AM
acamus's Avatar
Heh, ok, keep me updated.
Is there any chance we can get to SAE 1979 spec? I mean besides buying it?
Old Oct 15, 2008, 01:34 PM
dudical26's Avatar
hmmm, this should be really helpfull for evaluting tuning changes.
I'm gonna put this on the Evo tonight and play around with it this weekend.
Thanks
Old Oct 15, 2008, 10:34 PM
mrfred's Avatar
I wanted to plot pressure ratio vs airflow, so I went looking for a TD05HRA-16G6C (Evo 9) compressor map, but only could find the TD05HR-16G6 (Evo 8) compressor map. Here's where I'm at on that map:
Attached Thumbnails how-to: airflow rate in gm/s or lb/min and mpg-td05hr-16g6-lbmin_mrfred.gif
Old Oct 15, 2008, 10:58 PM
tephra's Avatar
i could never understand those comp-maps...
Old Oct 16, 2008, 06:37 AM
MR Turco's Avatar
Mrfred, what is the equation for figuring out lb/min or are you using logged values?
Old Oct 16, 2008, 06:52 AM
mrfred's Avatar
I'm logging it. The purpose of the patch is to use the ECU to calculate airflow rate. :-)
Old Oct 16, 2008, 03:32 PM
l2r99gst's Avatar
I used to do this on my old Eclipse and the compressor map for the turbo that I had. This is very good to help with seeing where you are on your map and how efficiently you are running in regards to the compressor.
It would be nice to see someone who is maxing out a stock turbo to show how far in the inefficient areas they are and how far to the right they manage to get to.
Eric
Quick Reply: how-to: airflow rate in gm/s or lb/min and mpg
