disable P0300 test
Old Oct 27, 2008, 08:45 PM
mrfred's Avatar
Originally Posted by draconx
add:
to your rom file. then when you open up ecuflash you will see 'ECU Periphery2', click on it and press the = sign up top on your keyboard. then enter in 0xEDCF and press enter. then reflash your car. thats it . ...
That value should only be used if you want to disable the EGR test as well.
Old Oct 27, 2008, 08:56 PM
draconx's Avatar
oh. mybad
Old Oct 27, 2008, 09:10 PM
mrfred's Avatar
Now that I have confirmation that I found the correct subroutine in the ECU code, the first post has be rewritten.
Old Oct 27, 2008, 09:58 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Holy crap this is huge, you da man!
Old Oct 27, 2008, 10:20 PM
draconx's Avatar
mrfred thank you!!!! this is awesome!!
Old Oct 28, 2008, 03:03 AM
cossie1's Avatar
Now I am confused as in the rom I use, bit 4 is at 0 by default.
Maybe the 7 roms are different ??
Old Oct 28, 2008, 06:36 AM
Kracka's Avatar
Awesome! I'm going to try this tonight since I've been plagued by this problem! Thanks as always mrfred
Old Oct 28, 2008, 06:57 AM
honki24's Avatar
A-mazing.
Old Oct 28, 2008, 07:10 AM
dudical26's Avatar
Originally Posted by mrfred
The code for the P0300 test is pretty long, so besides banishing the P0300 code by disabling the P0300 test, the ECU will be a little bit more responsive to critical engine control (e.g. timing and fuel control), so I may disable the P0300 test on my own car even though my car has never thrown a P0300 error.
Have you tested this? Does the ECU log faster or seem to respond quicker?
Old Oct 28, 2008, 07:35 AM
mrfred's Avatar
The code is a pretty small fraction of the total code length, so I doubt it would be a noticeable improvement in responsiveness, but every bit counts.
Old Oct 28, 2008, 08:57 AM
travman's Avatar
Mrfred,
I just got a call from danl - he has been driving the car around since you sent him the rom to try. He has not picked up the p0300 code and said he believes it was a definite success.
He is out of town w/ no computer access and wanted me to relay the message.
Old Oct 28, 2008, 09:11 AM
phenem's Avatar
Originally Posted by travman
Mrfred,
I don't believe you.....j/k
Good job guys!
~Zach
Old Oct 28, 2008, 10:17 AM
house_of_senate's Avatar
Still no code after the morning cold start!
THIS IS AWESOME
Old Oct 28, 2008, 11:37 AM
cossie1's Avatar
Ok looking at the JDM roms I have, they all seem to have bit 4 and bit 5 set to 0 by default.
However as I stated at the start of this thread, I have personally had the P0300 fault code come up twice, also another member on here has a JDM 8 MR and that too has picked up the P0300 fault in the past, but his rom is as above, set to 0 by default for bit 4 and 5
Old Oct 28, 2008, 12:13 PM
BarryC's Avatar
mate I have never had this code neither has any of the others I tuned
Quick Reply: disable P0300 test
