Evo wiki help for rom collection
Old Nov 25, 2008, 07:24 PM
Deepnine's Avatar
Hi,
on evo wiki (http://evoecu.logic.net/wiki/Main_Page) are only six different roms.
And lots of information is mission about them.
Because i'm having no evo, i can't even complete the information for my ecu. i don't know what car it is from. i bought it from ebay.
Now i'm asking to send me your stock roms with much information as possible. I will sort it and put it on evowiki.
Only stock files without tuning or mods.
What i need:
- rom id offcause
- car year, market (usdm,edm, jdm,....), model
- ecu case id or your vin will look for the case id (via email, i'll keep it confidential)
- xml file
- additional information like 2 byte stuff
and everything i have forgotten. as much information you like to write is good.
you can post here, or send me a pm, or email me the stuff to deepnine[AT]gmx.de
Just type all you know and you are willing to share. Also uncomplete information is better than nothing. Do as you like.
I have lots of infos i need to verify but asking for every detail takes to long, and will make no friends here, by getting 20 emails for each rom (i hope), i will see whats right.
I'll keep you updated here.
Thx Jan
Old Dec 3, 2008, 03:00 AM
Deepnine's Avatar
I have added some file now, thanks for you emails.
But most of them i don't know what car they came from. Or i have different information.
I need year, market and model for:
80700010
88840013
94170008
97250001
99270000
99860002
98650012
thx jan
Old Dec 3, 2008, 03:17 AM
tephra's Avatar
88840013 is early euro IX, ie they are upto 17 now.
94170008 is early US 8
80700010 GTA AU...
Old Dec 3, 2008, 04:07 AM
Deepnine's Avatar
Thx, wiki is updated
Old Dec 3, 2008, 04:54 PM
kkarim's Avatar
88840013/016/017 for the European (EDM) Evo IX GSR.
The EDM IX RS has a "JDM" 3-bar MAP sensor, and a different ROMID, but i forgot it.
EDM IX GSR doesn't have any map/mdp sensor, be it 3 bar or 1 bar.
Old Apr 9, 2009, 09:43 AM
Danieln's Avatar
80700010 GTA AU...
Hi Dave,
I had before this version of map.
I just wanna know if this map was deliver only to EURO side of the world or not.
Do you know more abiut this?
I`m not so sure that this map was delivered only to EUR side.
Evan if into ecuflash definitions maybe it was a mistake when they made the program and they add into the xml file of 88840013 ar ROM info, Market : USDM......I just wanna know if realy this was only a EUR map id.
Thanks
Old Apr 9, 2009, 07:05 PM
tephra's Avatar
i think its a mistake.
8884 was only EU AFAIK...
Old Apr 10, 2009, 12:35 AM
Mattjin's Avatar
Some info for the GTA
It is listed as AUDM but it was never available here. It is JDM only other than a few sent to UK I believe.
The rom on file is also not complete at 256k, it is only half of the rom. The full rom is 512k and a different read template is needed to download all of it.
2-byte Load is 6978-6979
2-byte RPM is 6956-6957
Old Apr 13, 2009, 02:32 AM
Danieln's Avatar
Hi Dave,
Allow me please to ask something about 88840013 Rom id version....
Evan this is an old rom is and not a very used rom ...... I still have some toughts about some options that I had when I was using this rom, option that I don`t find into my present rom 88840017.
First the inherits hierarchy between 88840013 rom is with evo9base not with evo9base_20081101 definition file.....
The following option apeear missing into my present map:
-boost enhacement (anti-lag start rpm witch was set at 2500 units
-min temp for full boost control (was set at 40*C
-boost enhancement (anti-lag) stop rpm (eas set at 4531 units)
-some options of setup the IC Relay Spray times corelated with lo and high temp and with vehicle speed
-air temperature compensation was set in *C
-min temp for closed loop (option that I definetly need to find and add for my present map since I still have this P0125 cell on)
Can you help me with some full or more updated definition files for 88840013 and 88840017 ROM`s.....other than Ecuflash 1.41 version???
I still must check about the differences between USDM cars and EDM cars.
I think AUSM are more ralated with EDM rom id`s and maybe you have more updated definitions for these maps.
**Off Topic**
Can you help me with a newer data definition file for Evoscan 2.5?
I must add some hex and xml files into evoscan folder in order to have also data for evo9?I see that inside ROMS folder in Evoscan exists a rom 88840013 but from a EVO& EDM from 2002......and the latest rom id is only for evo8......
I apreciate any help from you......
Take care
Old Apr 13, 2009, 02:57 AM
Danieln's Avatar
80700010
88840013
94170008
97250001
99270000
99860002
98650012
thx jan
97250001 = EVO8_GSR_Ralliart_2004_MT
99270000 = EVO8_EDM_2004_RalliArt
99860002 = EVOVII_JDM_2001
98650014 = EVO7_JDM_2002
Old Apr 13, 2009, 04:58 AM
Deepnine's Avatar
Wiki updated, thanks.
David Buschur
Oct 6, 2015 01:01 PM
TouringBubble
Aug 3, 2015 09:15 PM
fireroasted
Aug 15, 2012 05:57 AM
Appauldd
Apr 13, 2011 01:37 PM
LittleBlueMnM
18
Sep 14, 2008 01:47 AM
Quick Reply: Evo wiki help for rom collection
