using apexi avcr map sensor to log boost
Old Jul 5, 2009, 09:48 AM
leecavturbo's Avatar
using apexi avcr map sensor to log boost jdm8 2003
yes i have searched but can't find exactly how.
i want to use an apexi map sensor with a jdm e8 that doesn't have a map sensor oem.
so i need ecu pin number connections and what rom/xml entry's are needed?
TIA
my rom id is 96260009 3 plug ecu
SOLVED POSTS #6 & 7
Old Jul 5, 2009, 05:23 PM
ziad's Avatar
https://www.evolutionm.net/forums/ec...ing-boost.html
Old Jul 5, 2009, 06:57 PM
thx almost there but not quite.
not sure if my 3plug ecu is the same as the pin 73 mentioned?
i sure my rom will need some addition for this to work
and when john said log mut38 what does that mean?
Old Jul 5, 2009, 07:03 PM
ziad's Avatar
looking at the connectors (8gsr and 8mr) the spare connectors are 73/74. which correspond to mut38/39. both a 5V inputs.
so connect the wire to pin 73 and log via mut 38. the formula i use is (x*0.17573)-14.5
edit to check.. just hook up some wire giving voltage below 1 (maybe via resistor) or as i did check the voltage via multimeter on the blue wire. then log mut to see if you get a value bigger than 0
Old Jul 5, 2009, 07:20 PM
Old May 17, 2010, 05:41 AM
result today
logging on jdm 3 plug ecu
LC1 wideband on pin 73 mut 3c
Apexi map sensor pin 93 mut 39
Display="LC1 Afr" LogReference="LC1 Afr" RequestID="3C" Eval="7.35+(22.39-7.35)*x/255" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="10" GaugeMax="16" ChartMin="10" ChartMax="16" ScalingFactor="1"
Display="Boost Apexi pin93" LogReference="Boost" RequestID="39" Eval="0.19347*x-14.7" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="30" ChartMin="-15" ChartMax="30" ScalingFactor="1"
the reading in evoscan is a little lower than shown on my apexi which i hope to scale today
i.e 1.05 bar on the apexi showed 11.2 psi in evoscan
will try ziad's suggestion of 0.17573
Old May 17, 2010, 08:35 AM
and finally all scaled exactly
Display="Boost Apexi pin93" LogReference="Boost" RequestID="39" Eval="(0.18375*x-14.7)*1.47" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="30" ChartMin="-15" ChartMax="30" ScalingFactor="1"
Old May 22, 2010, 09:43 AM
2005Evo8's Avatar
Can this be done on the USDM Evo ecu?
Old May 22, 2010, 10:06 AM
yes its well documented for usdm
Old Jun 6, 2014, 01:52 AM
french's Avatar
Does this allow the use of PSI based boost tuning (providing that a JDM or OMNI MAP sensor is used) and does it allow the use of the AFR safety feature in tephra roms.
I am a JDM Evo 8 owner and info like this is hard to come by. Its almost like we need a separate sub section.
Old Feb 8, 2022, 04:07 AM
aqeelrizni's Avatar
Bump! Almost 8 years later. Anyone done this recently? On the jdm 3 plug evo viii?
cedmes
Jul 23, 2017 07:34 PM
fayez-winner
Feb 20, 2017 02:04 PM
mrfred
Jan 28, 2017 09:58 PM
EvoIXPilot
Mar 19, 2015 09:30 PM
wantanevo2
Aug 19, 2009 05:06 PM
Quick Reply: using apexi avcr map sensor to log boost
