Evo8 ECU in a 1G DSM in the works!
Old Jul 26, 2009, 06:29 PM
  #31
C130flyer's Avatar
Thank you Sir,
Where can I donate funds to help you do this.
Old Jul 26, 2009, 10:46 PM
  #32
mchuang's Avatar
Originally Posted by Jack_of_Trades
I will post up a SOLID layout in the next few days to help the next people who do this.
Please do, as I have a Gen 1 I want to try this on.
Old Jul 27, 2009, 08:46 AM
  #33
acidikjuice's Avatar
Knock sensor being 'deaf' ?
Whats up guys, I have been using an EVO ECU in my 2G for a few months now and LOVE it! I have a 6-bolt engine in my 2G with a 1G style CAS.
As far as the 1G knock sensor being deaf goes: I'm not sure if i have a 1G knock sensor or 2G knock sensor on my block any more and haven't really thought about the issues this might produce until reading this thread! I did the 6-bolt swap a long time ago and have forgotten if I did indeed swap the knock sensor or not.
I thought knock sensors were just a pickup for the signal and no processing of the signal takes place at the knock sensor. The ECUs may have different ways to process the signal (analog vs digital) but that this had no implications on the 'sensor' that the noise was coming from? this is because NO processing takes place at the sensor itself. I understand the knock sensor may be tuned for a specific Hz, but are the knock sensors from a 1G 2G and evo really that different? I can not imagine they are very far apart because all the 4G63s we are talking about are very similar in respect to the characteristics that factor into tuning a knock sensor Hz.
I can log knock (and lots of it) so I assume if I can read knock output that I at least have the 2G sensor on. But maybe i have a 1G sensor and thats why i get some odd knock counts at part throttle.
Thanks for your input on this issue.
Old Jul 27, 2009, 09:20 AM
  #34
EvoM Moderator
scheides's Avatar
JoT FTW! This makes me want a 1G again.
Old Jul 27, 2009, 09:39 AM
  #35
Jack_of_Trades's Avatar
The knock sensors are most CERTAINLY different in design fromthe 1g/2g's to the Evo8/9's. That, combined with theknock filters in the Evo ECU make it easiest to just toss an Evo8/9 knock sensor in it and call it a day.
Old Jul 27, 2009, 09:50 AM
  #36
4kinboost's Avatar
You guys never cease to amaze me with this stuff!!
Congrats on the new breakthrough!! You just raised the bar on what 1g's will be selling for shortly!!
Old Jul 27, 2009, 10:17 AM
  #37
the_mork's Avatar
I'm not sure how different the 2g knock sensor is from the 8/9. The 1g sensor is very different. The thing to note though is that on dsmtuners we have a member named knockgoon who has used the evo8 knock sensor on his 2g and it has not solved the phantom knock issues he had. What has worked has been to raise the knock multipliers to around 22 for the low and mid areas. The high range is just fine as it is.
The 2g knock sensor appears to have the same setup as the evo sensors AFAIK, nearly all of the signal processing is done internal to the ecu without a coprocessor or external chip. The 1g knock sensor appears similar and probably is nearly the same except that the signal is processed by a controller that resides within the ecu case which feeds the input for the ecu knock signal.
Old Jul 27, 2009, 10:31 AM
  #38
wreckleford's Avatar
Originally Posted by evonut270
jack see this link for the 2g maf scalings
http://www.dsmtuners.com/forums/tuni...-2g-works.html
Those MAF scalings actually aren't correct. I posted the correct scalings in the other thread we had here about the MAF adder. I have checked and double checked them. The good thing is that even with wrong scaling you can get the car to run pretty well by tuning.
Old Jul 27, 2009, 10:32 AM
  #39
Cool thanks. I found my timing issue to be the starter signal input wire. It was supplying +12v constantly which made the ECU keep the timing at only 5*, assuming that I was still cranking over the engine. Now I have to confirm every wire since they did a 4g63 swap in this mirage and obviously didn't hook up the wires correctly. fun fun.
I had this problem on a converted car once. Took a while to figure out.
Old Jul 27, 2009, 10:44 AM
  #40
Would you mind reposting a link to the post you made in the other thread to help others that happen to find this thread first???? My 2G MAF scaling is WAYYY off (used the DSMTuners scaling) so I would like to try yours.
Old Jul 27, 2009, 11:51 AM
  #41
https://www.evolutionm.net/forums/ec...maf-adder.html
This is the thread, but I didn't explain it as well as I thought. When I get home I can post it up.
Old Jul 27, 2009, 01:55 PM
  #42
GST Motorsports's Avatar
Very cool stuff!
I just missed a cherry blue 90 GSX last week, single owner, garaged it's whole life, blown turbo for $1500.
Time to go DSM shopping again.
Bryan
Old Jul 27, 2009, 03:33 PM
  #43
0xDEAD's Avatar
Get an auto Bryan
  #44
C130flyer's Avatar
Is it just me or is it getting stupid hard to find a nice 1g these days.
Old Jul 27, 2009, 03:34 PM
  #45
0xDEAD's Avatar
Stupid hard. I have two good ones.
Quick Reply: Evo8 ECU in a 1G DSM in the works!
