Evo8 ECU in a 1G DSM in the works!
#579
So the MAF scaling on V7 now has the maf adder added in? I finally figured out why my patch harness wasn't work (or should I say corrupt v7 file) and now I'm trying to figure out how to set the MAF scaling for a stock 1g maf. Anyone have the scaling table since the table posted by Broke4speed above is for the MAF adder itself?
#580
I know I've asked this before, but does anyone have a known working ROM for a stock 1g? Looking for a bone stock ROM to use to diagnose a few locals cars without modifying their car much. I have the injector scalings, but for whatever reason can never get the MAF scalings working.
#583
I found a form of the 1g scalings on the ecmtuning site somewhere but when I started to get into it I decided that it would be easier to just grab the correct MAF from a junkyard and throw that in my car. EVO8 ecu in a GVR4 for over a year here.
#584
That works fine in my own car but i have a spare computer i use for diagnosing locals cars and need to be able to diag on stock cars.
#585
Well, you can pull the numbers from the 1G bin file easily enough, with tunerpro. There isn't a MAF smoothing table though, so you'd be stuck using the EVO 8 one, which is tuned for an EVO 8 MAF. You could input the 1G MAF scalings, but the smoothing table would be wrong, so there's technically no 'out of the box' answer. If you had a 1G MAF, and some time, you could create a proper table by logging and making each hz/rpm/load point match the fuel map...but that could take some time.
An EVO 8 MAF and 1g-to-evo harness adapter would be the only way to do it easily, IMO.
