ECU ROM mod - double the "Fuel Cut Load Limit" range to 638
#33
#34
This thread is getting way off track. :-) But, yes it is possible. Can't say off the top of my head whether its feasible. I'd have to look in the ROM at what's on either side of the major tables. I guess before I dive into something like that, do you really think it would be helpful? What size RPM and load interval do you think would be beneficial over the stock intervals?
#35
As for load, I know some on here are already hitting 480+ load, so maybe another 5-10 load sites ontop of what we currently have ?
#36
#37
It may be easier for tephra to incorporate this into his altmaps. I'm pretty sure he uses the same axes for the altmaps and stock maps, but if that were changed, adding more columns should be trivial I would think, since he is already creating the alt maps in unused space in the ROM. So, making the table bigger shouldn't be an issue. Of course, you would have to run that by tehpra to be sure, as I am just assuming.
#38
#40
I added a thread to discuss the map resolution topic here:
https://www.evolutionm.net/forums/ec...ml#post7556777
Lets keep that topic separate from this one so MrFred's thread doesn't get off topic too much
#43
Since tephra does away with all the 1,2,3 maps, that frees up some space in the main data storage space. However, there no 1,2,3 fuel map, so the fuel map may have to be moved to another location in ROM. Its all doable. Perhaps I should get with tephra before he goes final on his v7.
