TephraMod V7
Old Jan 31, 2017, 06:53 PM
  #3406
Kieran Fercher's Avatar
Old Jan 31, 2017, 06:55 PM
  #3407
Originally Posted by eazlan
I have the basic 96260009_v5.10_TephraV5 if you want. I'm ok to deliver for you
That'd be awesome mate, my email is kieran.fercher@gmail.com if you want to send the files through there.
Cheers
Old Feb 1, 2017, 04:20 AM
  #3408
eazlan's Avatar
Evo 8 JDM
Cheers
Hi , I've send to your mail... cheers !
Old Feb 4, 2017, 07:27 PM
  #3409
jimersees's Avatar
Hi guys
I have sent a donation to tephra in regards to a rom that I'm looking for.
Rom I need is 88581713 for ADM Evo 9 With speed density.
Iv sent messages to tephra but have not got a response. Does anyone have the above rom? Or can help me.
Kind regards
Jimmy
Old Feb 9, 2017, 06:42 AM
  #3410
eazlan's Avatar
Hi Guys, Is there anyone using ROM ID 96260009 that upgraded with Speed Density ( Non Using MAF ). I'm now trying to use 96260009_v5.10_TephraV5 but this ROM need MAF. If you guys have, kindly share the bin and xml file.
My ride is Evo 8mr JDM version.
Old Feb 20, 2017, 10:08 PM
  #3411
synmaster941's Avatar
evo 7 (90550001)
got it
Old Feb 21, 2017, 12:14 AM
  #3412
tephra's Avatar
Originally Posted by synmaster941
I donated last week and still waiting on a copy
sorted..
but saturday isn't really last week
Old Feb 21, 2017, 09:35 AM
  #3413
Originally Posted by tephra
sorted..
exposed
Old Feb 21, 2017, 12:36 PM
  #3414
SH0F's Avatar
hi tephra
first i must apologize as your most likely bombarded with these type of emails(mailbox full so i posted it)
i have been reading and searching the forums trying to put the dots together(been all over the place) so i thought might aswell ask the guru, if you have some time for me, ill keep it short
my rom im running is 96260007 at the moment
what would be the best upgrade for me(96260009??)
i want to run the maf for the time being but maybe in the future i would like to run sd
thanks for taking time to reply
Old Feb 22, 2017, 09:02 AM
  #3415
jcar6794's Avatar
Hello! I am new to open forum tuning. I have an evo 9 usdm. rom id 88590015. I am looking to convert to speed density. Looking to donate for the cause and get a download for a patch. any help would be great I am new to this forum and open forum tuning in general I understand the function of the stock evo ecu and know how to add the xml and bin data.
Old Feb 22, 2017, 09:05 AM
  #3416
jcar6794's Avatar
tephra mod v7
Hello I am new to the open forum tuning world. I am looking to donate for the cause. looking for a patch download to convert to speed density for evo 9 rom id 88590015 usdm. any help would be much apprecitated.
Old Feb 22, 2017, 11:15 AM
  #3417
ant_turbo's Avatar
I'm a little slow mined where do I find this setting location , Do I open ECU FLASH,, and what part and where do I change this..
Thanks.
Originally Posted by RoadSpike
In the programming section there is a small 1D table for setting the input for MAT.
Fuel temp sensor location is 0xE while maf IAT location is 0x3. Just change the numbers accordingly.
Old Feb 23, 2017, 06:22 PM
  #3418
RelentlessEVO's Avatar
Can someone explain to me why my car won't start on the 88590715 rom? I made sure that the internal ECU id as well as the immobilizer code are identical. I am switching from the SD rom (88591715) to the MAF rom but I have my MAF hooked up. I have no idea why it won't start. It just cranks and cranks (like the immobilizer is active). Any ideas?
Thanks!
Old Mar 2, 2017, 02:02 AM
  #3419
Thrive's Avatar
Hello! (I speak English very bad, sorry). I need help. My problem: My car Mitsubishi Carisma, 4G92 engine. Installed TD04L turbo from Subaru. To manage the supercharged electron, I installed ECU EVO9. I use the MAP sensor installed Blow-off. The firmware using Tephra 88586714. Engine starts, but there are P1021 and P1012 error - this is understandable, because the 4G92 engine has one camshaft and has MIVEC. Please tell me how to disable these errors. When using firmware Tephra EVO8 96534706 of these are no errors, but this firmware has Jitter bag, for this I do not want to use it.
Old Mar 16, 2017, 07:37 PM
  #3420
TurkoTec's Avatar
Hey
Is is this the tephra v7?
Originally Posted by 400s
Quick Reply: TephraMod V7
