TephraMod V7
Old Oct 10, 2009, 06:13 PM
  #61
phenem's Avatar
Originally Posted by alan678
Can anyone confirm that the stoopid CEL for the Idle control systems is infact not an issue anymore?
Correct this is not an issue anymore. It has been fixed if you use one my pre-patched ROM's from the second post.
Old Oct 10, 2009, 06:14 PM
  #62
phenem's Avatar
Originally Posted by Chris Moore
Sorry let me try to make my question more clear. When we change it over to load based boost, does it already come with mrfreds settings to follow 2 byte instead of the factory based load it follows? If not, can we switch it over like normal?
Thanks again
Read my first post under Tephra's first post. It will explain everything. Read it, then read it again, then read it one more time. I think I made everything pretty clear there.
Old Oct 10, 2009, 06:21 PM
  #63
EvoM Moderator
scheides's Avatar
Is this version any different than v7t5?
Old Oct 10, 2009, 06:23 PM
  #64
RALLInspired's Avatar
please excuse the ignorance as i haven't followed the development of these mods. what is the point in including the normal Ignition and fuel maps? im having a little trouble understanding how these come into play vs the BIG maps
Old Oct 10, 2009, 06:25 PM
  #65
phenem's Avatar
Yes! VERY DIFFERENT! Download the map and check it out, read Tephra's first post it lists all the things that are in this final v7.
Old Oct 10, 2009, 06:26 PM
  #66
phenem's Avatar
Explain what you are asking here, BIG MAPS replaces the normal fuel/ignition maps. Is that what you mean?
Old Oct 10, 2009, 06:29 PM
  #67
Question
yes the BIG MAPs replace the normal map. that i understand. im simply asking why the normal maps were included? do they still play a role?
thanks
Old Oct 10, 2009, 06:30 PM
  #68
phenem's Avatar
Anyone have an FTP site that can give me an account to host the modified files? My FTP is running out of space and my bandwidth from my provider is not unlimited!
Old Oct 10, 2009, 06:32 PM
  #69
phenem's Avatar
thanks
OK I understand what you mean now, Tephra left them there because they are used for other things and he didn't want to change the reference points on those too. You shouldn't have to change those maps just leave them be stock. Just edit the NEW BIG MAPS and you should be good to go
Old Oct 10, 2009, 06:37 PM
  #70
tephra's Avatar
your normal fuel and ignition maps are NO LONGER used - use the new ones under the "TephraMod V7" catagory in ECUFlash
you should find that changing the old ones has no affect on the tune.
  #71
Jack_of_Trades's Avatar
I have a website that I can host them on, just email the files to me and I'll send back the links.
Old Oct 10, 2009, 06:38 PM
  #72
mountainturbo's Avatar
Man I think you guys have finally inspired me to switch from my stock tuned rom
Thanks for the hard work!
Old Oct 10, 2009, 06:39 PM
  #73
phenem's Avatar
I am looking for an FTP site so I can manage and upload/delete the files myself. Takes less hassle and human error out to make sure the most recent files are there and what not. I am OK for now but by the end of this month I need to find somewhere to put them....
If it comes down to it when we have been running this for a while and there are no more issues that come up. I will send you them and you can host them since we won't be changing anything anytime soon.
Old Oct 10, 2009, 06:41 PM
  #74
phenem's Avatar
Tephra on my modified version Jack_of_Trades made up an XML and organized everything better and put the new BIG MAP under the fuel/timing areas respectively. They are clearly marked NEW BIG MAP
Old Oct 10, 2009, 06:49 PM
  #75
alan678's Avatar
Awesome...thanks! That drove me NUTS!
Quick Reply: TephraMod V7
