ECU Flash on 2010 Ralliart Sportback.
Ok here you go.
Need somebody, hopefully tephra, to find mode23 and airflow/torque disablers but everything else is pretty much there:
base XML file:
http://norcalmotorsports.org/users/b...lliartbase.zip
Put this in:
\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
55590006 XML:
http://norcalmotorsports.org/users/b...l/55590006.zip
Put this in:
2010 Lancer ralliart Rom - 55590006
http://norcalmotorsports.org/users/b...M_55590006.zip
base XML file:
Put this in:
55590006 XML:
Put this in:
I was looking at my now viewable maps, comparing them to the base map and boost pill maps that you gave away... from looking at my stock maps do you see any changes that would prevent me from sucessfully using the base map you provided? Also, I checked your website figuring to purchase a boost pill from you since you provided the cool base maps for free to people, but didn't see one listed anywhere... so do you use the AMS boost pill? I will be at AMS this afternoon and will pick up the boost pill if it will work with your boost pill map.
Thanks for all your help,
Keith
PS: Is the base map you provided here just a copy of mine, or is it slightly altered to work better with logging software, and play with torque and air flow limiters? Just a bit confused on that
Thank you soo much!
Keith
PS: Is the base map you provided here just a copy of mine, or is it slightly altered to work better with logging software? Just a bit confused on that
Keith
http://www.gstmotorsports.com/store/...oducts_id=1050
it's mainly a service item we offer. If it's easier for you to get the AMS pill, and it's the same size as ours, by all means, do what is easier for you.
the rom I attached here is the 100% stock OEM rom provided by you.
From looking at the stock rom, it looks like the GST BaseFlash should work, just need to make a version of it for the 2010.
If you want to log via Evoscan, just change the mode23 entries in the rom.
We have our own boost pill that we have offered for over two years now:
Keith
Also, looking over your site... you are probably missing out on some sales by not updating the EVO X section. Under "interior" there is nothing listed... but under the EVO IX section for "interior" you have a crap load of gauges for sale. People looking for gauges for the X may not look elsewhere on the site, and then you miss out on a sale.
Keith
Can you help me with the european version? I loaded this image and my car wouldnt start. Cant write to protected area or something. So i reloaded the original and its up and running again.
Heres my original rom 2010 sportback ralliart europe:
http://rapidshare.com/files/41325382...art_Sweden.hex
Are you 100% it's a 2010 model and not a 2009?
Let me know and I will try to make a xml for you. This also helps so that I can make a EDM GST BaseMap for you guys.
- Bryan
I bought it brand new as a 2010 model from mitsubishi motors in stockholm, that's the only "proof" i got.
I think it's weird that we don't get the color display like some of you with 2010's got, but instead we have the HID's and few other stuff in the package.
Hope it helps!
//Toby
Hope it helps!
//Toby
Your rom ID is 53610013
- Bryan
- Bryan
