ECU Flash on 2010 Ralliart Sportback.
#31
Checked some swedish 2010 reviews and some other people's 2010's and they all have the orange/one colored display here so yea, should be correct! That's the only thing that made me confused. I'm 100% sure I have the start in hill assist and that's just in the 2010 right?
//Toby
//Toby
#32
//Toby
//Toby
- Bryan
#34
Ok turns out this is the same rom as the AUS 2010 RA, 53610013.
Which means the 2010 AUS GST Basemap will work with EDM 2010 models as well! I'll make the update in the GST Basemap thread
Attached is XML for your rom
- Bryan
- Bryan
#35
I can feel a difference already.
#36
Hello. Can anyone make .xml file for this european 2009 Ralliart? Thanks.
http://178.130.33.198/ra09eu_image.zip
#38
#39
base XML file:
http://norcalmotorsports.org/users/b...lliartbase.zip
Put this in:
\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
55590006 XML:
http://norcalmotorsports.org/users/b...l/55590006.zip
so i just put these two in the folder and im good to go with the 2010 gst maps. So is the 2010 maps runing off the 2009 maps.
Put this in:
55590006 XML:
#40
Just for the record, we found a new ROM ID on an AUSDM Sept 09 RA: 53610012. The XML is the same as the 53610013, so just rename the file and fix the info in the XML and it should open.
#41
Brian,
I bought a pill from you guys and downloaded the maps, the only problem is i cant find the xml file!
Where can i get it? ID#: 55590007
thx
thx
Ok here you go.
Need somebody, hopefully tephra, to find mode23 and airflow/torque disablers but everything else is pretty much there:
base XML file:
Put this in:
55590006 XML:
Put this in:
2010 Lancer ralliart Rom - 55590006
http://norcalmotorsports.org/users/b...M_55590006.zip
base XML file:
Put this in:
55590006 XML:
Put this in:
#42
Replace the header in the 55590006.xml with this:
<rom>
<romid>
<xmlid>55590007</xmlid>
<internalidaddress>5002a</internalidaddress>
<internalidhex>55590007</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>Ralliart</submodel>
<transmission>SST</transmission>
<year>2010</year>
<flashmethod>mitsucan</flashmethod>
<memmodel>M32186F8</memmodel>
<checksummodule>mitsucan</checksummodule>
</romid>
Then save as 55590007.xml
- Bryan
<rom>
<romid>
<year>2010</year>
</romid>
- Bryan
#44
regan6678
Mar 28, 2014 06:34 AM
Jdubya
Aug 13, 2013 04:46 AM
EvoXHoosier
Mar 15, 2011 06:18 PM
