launch maps
#166
is that all because i dont have a cat i have a full straight pipe into a Espiller JGT 500 Muffler. and im not sure how long i am going to stay stock turbo but mine is in pretty good condition. say i wanted to tell my tuner exactly what kind of twostep i am looking for what would u say AFR's around what? and what kind of timing? or is it easy enough to do myself?
#167
You shouldn't need launch maps on a stock turbo, I build 10psi at 5k rpm on mine with just the stock 2-step, which is plenty to get out of the hole at the drag strip.
Anyways, I haven't played around with them much myself so I don't know what AFR would be good. Timing would need to be in the negatives, probably below -10 if you want flames. There are a few examples of launch maps in here, check those out to get an idea of what you'd be doing.
Disclaimer: I'm not responsible for any damages incurred to your car from tuning it to shoot flames on the 2-step.
#168
#175
Gear-based boost control should atleast help keep your stocker alive. Either way though, launching 400+whp on a stock clutch is bound to end badly eventually And if you already have too much power for the stock clutch on launch, don't use launch maps, you'll just have even more torque from the added boost.
