launch maps - Page 18 - evolutionm.net
launch maps
Thread Tools Search this Thread
Old May 26, 2014, 02:46 PM   #256
211ratsbud's Avatar
Drives: currently walking
gambino, how long can you hold on the limiter? You should be able to work the "tree" with out knock and for the style of lights you run(.400 or .500 pro etc)
Offline
Old Dec 8, 2014, 05:40 PM   #257
mines5's Avatar
Drives: Evo7, Evo 8 GSR, GT-R
bump
Do i need to install some kind of hardware to get these pops and bangs on launch and build boost ? or these launch maps will simply work by just retarding the timing and richening the AFR at relevant areas ? Evo 8 jdm, hks twin power, hks ssqv bov.
Online
Old Dec 8, 2014, 06:58 PM   #258
Raptord's Avatar
Drives: AS Evo IX SE
No additional hardware needed.
Offline
Old Feb 27, 2017, 03:37 PM   #259
Drives: 05 Evolution GSR
Bringing an old thread back to life.... lol sry
I've been playing around a lot on it lately and I think I'm starting to get the hang of it.. but few things I don't understand...
under Limits am I suppose to change anything from there? it was at 59.9 to start off with but when I was using EvoScan doing the live viewing everything across the map was showing 60
now that I've changed it to -15 I'm able to see it drop of -10 where I have it set to -15
I'm getting a lot of banging and building about 11-13psi
Offline
Old Feb 28, 2017, 03:07 AM   #260
Lion_Sam's Avatar
Drives: Evo IV GSR
I'm interesting of turbo lifespan when using 2-step launch. Because I'm think it's like hit with a hammer to impeller.
Or not?...
Offline
Thread Thread Starter Forum Replies Last Post
Tephra 7 Alt Maps/Launch Maps issue Raceghost EcuFlash 1 Nov 16, 2016 08:53 PM
launch maps tephramod unfocus15 Evo X Engine Management / Tuning Forums 0 Apr 22, 2015 07:50 AM
launch map issue - car stalls stunt2 EcuFlash 9 Nov 11, 2014 05:16 AM
tephra launch maps awdordie EcuFlash 33 May 18, 2014 08:17 PM
stationary rev limit issue tuning launch maps 211ratsbud EcuFlash 2 Nov 27, 2012 08:06 AM
Tags
96532706, activate, control, ecu, evo, evom, fuel, lanch, launch, map, maps, mitsubishi, stock, tephra, v7
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
