How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
Old Aug 18, 2014, 09:20 AM
  #301
mavraolan's Avatar
Originally Posted by domyz
Yes it's true and boosting maximum 14,5psi in an evo is not a great idea. You need at least a 3bar map sensor (good up to 29psi) but I would suggest a 4bar sensor (up to 43psi) because it's the same price
You can trust scheides. Look who wrote the very first post of this thread.
14.5 psi is not that bad idea for a stock evo
ok! scheides start and wrote the very first post of this thread and I am not doubting anything from what he is saying.
I am just trying to figure out why Tom said I'll be fine but scheides says that can't be.
Maybe has something to do with JDM and USDM etc ?
Old Aug 18, 2014, 10:26 AM
  #302
domyz's Avatar
Ah! so you have a JDM map sensor, and it's a 3 bar so yeah it's okay
But no, 14,5psi is not a good idea even on a stock evo, unless you want to produce 240hp instead of 280hp
Old Aug 18, 2014, 02:27 PM
  #303
mavraolan's Avatar
Yes! I said in my previews post that my car is JDM IX. I didn't know it was 3 bar...i thought was 2. Anyway.
My car bone stock,from the factory was 11.6 psi and produced 282hp. I am not lying and I have no reason to lying about it. Actually still it is producing 282hp at 11.6 psi since the first tuner I went didn't touch much the stock map, he just did the alternative maps.
Old Aug 18, 2014, 02:31 PM
  #304
mavraolan's Avatar
ah! 14,5 psi full boost! but is set from 11.6 overboost to 14,5 and produce 282hp! I guess JDM might be little different!?
Old Aug 18, 2014, 05:57 PM
  #305
domyz's Avatar
Might be. Would be surprising but might be.
USDM spike at 19 and taper at 17psi psi stock
Old Aug 19, 2014, 10:56 PM
  #306
tscompusa's Avatar
2 bar = 29psi So why can't boost more than 14.5psi?
Just asking...I don't really know that things. My evo 9 JDM has this stock 2 bar map sensor and I asked Tom from tscompusa if I need to upgrade to go SD and he said "no" I don't need to upgrade. And I am sure he is going to tune it more than 14,5 psi
Am I missing something?
No i prefer a omnipower 4 bar. I have like 40 of them here in stock. I stock them for a reason.
I don't want you to use the stock map sensor. I think we misunderstood each other.
Old Aug 20, 2014, 03:49 AM
  #307
domyz's Avatar
If he want to save money for other parts, a Jdm 3 bar is plenty enough for boosting 23-24 psi with a safety margin
Old Aug 20, 2014, 04:19 AM
  #308
m.al-hassawi's Avatar
Originally Posted by m.al-hassawi
yeah i already ordered the OMNIPOWER 4bar, but i was trying yesterday on the OEM MAP the car wouldnt start it seems that it was very rich i played around with the VE Tables and it was the same?
hii do anyone has an answer to my issue ??
Old Aug 20, 2014, 04:34 AM
  #309
domyz's Avatar
Reduce RPM VE until the car's running fine again. Do you have stock injectors?
Old Aug 20, 2014, 04:36 AM
  #310
yes stock injectors?
Old Aug 20, 2014, 05:35 AM
  #311
mavraolan's Avatar
Oh God! I also send you a photo of the intake. You are so busy it's ok Tom, no problem. So, If I don't do SD, do I need the omnipower 4 bar? Are you going to do it more than 23-24 psi?
check your emails pls.....we need to talk
thx
Old Aug 20, 2014, 05:52 AM
  #312
mavraolan's Avatar
.....by the way I just remember that my car is now start boosting at 20.5 psi and goes up to 26.5 psi.
So i think is not just boosting at 23-24 psi. I guess is 2 bar sensor, so is 29 psi!!
Have anyone try it on a JDM car or you all talking about USDM?
Old Aug 20, 2014, 12:49 PM
  #313
tscompusa's Avatar
Ive tuned plenty of JDM evos on speed density.
No you do not need to touch the map sensor if you're using a maf.
If you want to log past whatever the map sensor is capable, thats the only time you need to change it on a maf
I just have people upgrade to 4 bars to give a good range on SD for later use. you dont want to small vs to big when the map sensor is that important.
For MAF tuning you can leave it alone though.
Old Aug 20, 2014, 01:15 PM
  #314
domyz's Avatar
Even on SD like he wants to go a JDM 3 bar is plenty enough and safe unless he have the setup and fuel to go over 26-27psi
Don't even know why we are arguing about that, or are we not?
Old Aug 20, 2014, 01:30 PM
  #315
mavraolan's Avatar
ok everything is clear...thx
Quick Reply: How To: Speed Density on the evo8 using tephra v7/Phenem pre-patched roms
