Going back to 94170015
Old Jul 17, 2010, 08:46 AM
  #226
Appauldd's Avatar
It won't show 3 digits. I just copied and pasted it.....the paste shows the extra digits. Don't worry about it.
Old Jul 17, 2010, 08:50 AM
  #227
charlie.tunah's Avatar
gotcha. now it matches the format of 9653 for some reason...wierd. thanks man. Still not working 100% for me (still stalling at clutch in), but now that Im trying my tuned maf scaling, it may be better.
Old Jul 17, 2010, 08:54 AM
  #228
Appauldd's Avatar
Your stock rom is the 96940011....it is very finicky to get running right. Some will like the 9417 while others will like 9653.
The key is to make EVERY table have the same exact values as your stock rom....THEN start tuning.
Leave the Periphery bits as they are with a stock 9417 or stock 9653....don't use your 9694 values in the peripheries as each rom operates slightly different.
Old Dec 14, 2010, 06:53 PM
  #229
AutoXer's Avatar
Appauledd,
Has anyone found this table yet?
ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph] (sub_1EFC0)
It appears incorrect in the XML on the wiki. This is the table that needs lowered (or zeroed) to reduce throttle hang, correct?
Old Dec 16, 2010, 09:52 AM
  #230
Jorge T's Avatar
A 03 should not have throttle hang. It can be your throttle cable is too tight and when you let off the acc pedal, the rocking motion of the engine back and forth, will make your rpm rise and hang as you lift off at redline. I went through this 2 yrs ago and it ended being the darn cable was too tight.
Old Apr 13, 2011, 01:37 PM
  #231
shadow1's Avatar
Old thread but when I compare the stock ISCV tables from 94170715 to 96940011, some of them are totally different. Makes me think that the tables are not defined or labeled correctly.
Boosted Tuning
Aug 26, 2023 10:14 PM
mrfred
Aug 1, 2022 06:05 AM
simple_lancer
Oct 14, 2020 02:18 AM
ziad
Jun 11, 2017 12:38 PM
kaganader2
Feb 24, 2014 11:24 AM
Quick Reply: Going back to 94170015
